8G5L0T Posted April 24, 2007 Report Share Posted April 24, 2007 For those of you that have taken your turbos off, did you take the exhaust manifold off with it or just the turbo? Is one way easier than the other? Link to comment Share on other sites More sharing options...
gdizzle Posted April 24, 2007 Report Share Posted April 24, 2007 For those of you that have taken your turbos off, did you take the exhaust manifold off with it or just the turbo? Is one way easier than the other?just the turbo, it'd be a PITA to take the manifold off w/ the turbo on it. Link to comment Share on other sites More sharing options...
Boosted5cyl Posted April 24, 2007 Report Share Posted April 24, 2007 how long to get the 16T off Greg ? Link to comment Share on other sites More sharing options...
8G5L0T Posted April 24, 2007 Author Report Share Posted April 24, 2007 thats what i was thinking. it just doesnt look like there is alot of room to manuever the turbo out of the manifold. wish me luck with the new turbo today Link to comment Share on other sites More sharing options...
gdizzle Posted April 24, 2007 Report Share Posted April 24, 2007 how long to get the 16T off Greg ?depends on your skills/tools. It took me about 45min if that IIRC. 3 bolts on the down pipe, 4 bolts holding the turbo to the manifold(2 have to be removed from under the car), 2 oil return bolts, 3 banjo bolts, 2 vac lines, turbo inlet pipe, and UPICP have to be removed. If you have a strut brace, take that off too depending on the turbo. Link to comment Share on other sites More sharing options...
8G5L0T Posted April 24, 2007 Author Report Share Posted April 24, 2007 are there any gaskets i need to replace? Link to comment Share on other sites More sharing options...
gdizzle Posted April 24, 2007 Report Share Posted April 24, 2007 sounds like all i need to know. are there any gaskets i need to replaceYes, oil return gasket and o-ring, and crush washers on banjo fittings. You need 6 crush washers. Link to comment Share on other sites More sharing options...
8G5L0T Posted April 24, 2007 Author Report Share Posted April 24, 2007 turbo is off Link to comment Share on other sites More sharing options...
gdizzle Posted April 24, 2007 Report Share Posted April 24, 2007 turbo is offuhh... that's cool? :unsure: Link to comment Share on other sites More sharing options...
8G5L0T Posted April 24, 2007 Author Report Share Posted April 24, 2007 lol Link to comment Share on other sites More sharing options...
8G5L0T Posted April 25, 2007 Author Report Share Posted April 25, 2007 ive gotta a little problem. when we filled the car up with water to test it the coolant lines leaked big time. how are the seal and 2 gaskets suppose to stay together without leaking? how do they go in? Link to comment Share on other sites More sharing options...
skylerwaite Posted April 25, 2007 Report Share Posted April 25, 2007 depends on your skills/tools. It took me about 45min if that IIRC. 3 bolts on the down pipe, 4 bolts holding the turbo to the manifold(2 have to be removed from under the car), 2 oil return bolts, 3 banjo bolts, 2 vac lines, turbo inlet pipe, and UPICP have to be removed. If you have a strut brace, take that off too depending on the turbo.haha, it took me... 6 hours to get it off? it was pretty much the first thing i've ever done to any car. if i did it again it would probably only take about an hour. Link to comment Share on other sites More sharing options...
8G5L0T Posted April 25, 2007 Author Report Share Posted April 25, 2007 haha, it took me... 6 hours to get it off? it was pretty much the first thing i've ever done to any car. if i did it again it would probably only take about an hour.you have any pointers on how to not get the coolant line (running from the block to the turbo) to leak Link to comment Share on other sites More sharing options...
gdizzle Posted April 25, 2007 Report Share Posted April 25, 2007 ive gotta a little problem. when we filled the car up with water to test it the coolant lines leaked big time. how are the seal and 2 gaskets suppose to stay together without leaking? how do they go in?uhhh. those are oil return line gaskets and o-ring. The water line that sits over top of the oil return line has a banjo fitting, it gets a copper crush washer on both sides of it, turbo side and bolt head side.banjo bolt and crush washers..banjo fitting, notice washer on both sides.. Link to comment Share on other sites More sharing options...
550 Posted April 25, 2007 Report Share Posted April 25, 2007 took me about 2 hours my first time. Had some snags, took turbo off only. BUy new crush washers, as you will probably lose them in your bucket of oil and cooant. Link to comment Share on other sites More sharing options...
