volvos60t5x Posted May 12, 2007 Report Share Posted May 12, 2007 hi there everyone, well after 5 electronic turbo valves(i think thats the correct name) im so tired to see my boost gauge in 6 psi. As some members know my car after some hard accelerations the boost drop to 6 psi and will never be the same (22 psi) if i dont change the valve for a new one and resett the computer. Someone told me that i can leave the valve connected and install a manual boos controller on the hoses. Any ideas? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted May 12, 2007 Report Share Posted May 12, 2007 http://volvospeed.com/Mods/dawes_mbc.htm Link to comment Share on other sites More sharing options...
Che'_Moderator Posted May 12, 2007 Report Share Posted May 12, 2007 http://volvospeed.com/Mods/dawes_mbc.htmHis car is not 4.3 Bosch Link to comment Share on other sites More sharing options...
Piglet Posted May 12, 2007 Report Share Posted May 12, 2007 His car is not 4.3 BoschThe car will detect it even if he sets it at the max boost that the chip will allow? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted May 12, 2007 Report Share Posted May 12, 2007 The car will detect it even if he sets it at the max boost that the chip will allow?Its not just about where its going, its about how it got there. You need to find out whats wrong or who screwed up what. Who programed your ECU? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 12, 2007 Report Share Posted May 12, 2007 I think it is essential to know who did your tune? Any issues before the upgrade? I know the TCV is groundside switched through the ecu, so maybe something was damaged in the ecu when it was upgraded? Link to comment Share on other sites More sharing options...
Johann Posted May 12, 2007 Report Share Posted May 12, 2007 Read the sig, it's BSR.And from past posts I recall the spike were there all along. Check all the hoses. When finished check them all again. Put clamps on them if in doubt.Check the wastegate actuator if it is mounted properly. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted May 12, 2007 Report Share Posted May 12, 2007 His car is not 4.3 BoschYeah, I know, but who am I to deny him the opportunity of finding out if something works or not on his particular car with his particular tune. Speaking of tune... I'd say the original poster has to talk to his tuning company and see why it's eating the stock boost controller, have they had this issue on any other cars? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 12, 2007 Report Share Posted May 12, 2007 Read the sig, it's BSR.And from past posts I recall the spike were there all along. Check all the hoses. When finished check them all again. Put clamps on them if in doubt.Check the wastegate actuator if it is mounted properly.I overlooked that BSR had done the tuning in his sig. Thanks for pointing it out Does the the new TCV valve crap out the first time you try to go into full boost or does it gradually die? I've put lots of TCV valves on cars, but never 5 on the same one. That is madness! Link to comment Share on other sites More sharing options...
volvos60t5x Posted May 12, 2007 Author Report Share Posted May 12, 2007 I overlooked that BSR had done the tuning in his sig. Thanks for pointing it out Does the the new TCV valve crap out the first time you try to go into full boost or does it gradually die? I've put lots of TCV valves on cars, but never 5 on the same one. That is madness!its weird....the car run fine for 1 week for example and then the psi drop to 6, if i reset the ecu with my ppc it work again the car another few days. Thats why im trying to see if is possible to keep the tcv connected on the car and put a mbc on the houses. I think is the TCV cause everything on the car seems to be fine. Im so sad to have all this setup on my car and just enjoy a couple of days a week. Link to comment Share on other sites More sharing options...
volvos60t5x Posted May 12, 2007 Author Report Share Posted May 12, 2007 Read the sig, it's BSR.And from past posts I recall the spike were there all along. Check all the hoses. When finished check them all again. Put clamps on them if in doubt.Check the wastegate actuator if it is mounted properly.how do i check that my frien Johann Link to comment Share on other sites More sharing options...
Texas850Turbo Posted May 13, 2007 Report Share Posted May 13, 2007 Hoses- if you want to do a thorough job, I'd take em all off, inspect carefully for any cracks that could be opening up under boost, and make sure they're installed back on correctly with a nice set of clamps. Wastegate actuator-? someone else take this one... Link to comment Share on other sites More sharing options...
volvos60t5x Posted May 14, 2007 Author Report Share Posted May 14, 2007 Hoses- if you want to do a thorough job, I'd take em all off, inspect carefully for any cracks that could be opening up under boost, and make sure they're installed back on correctly with a nice set of clamps. Wastegate actuator-? someone else take this one...let me check my friend and also i will tell my mechanic to check the wastegate actuator. So before put the boost controller is better to check the hoses right?. Link to comment Share on other sites More sharing options...
volvos60t5x Posted May 16, 2007 Author Report Share Posted May 16, 2007 question, i know that ihave to leave the tcv connected to the wire, and set the mbc at the psi that my remap has, but the ECu will not have problems at all? Link to comment Share on other sites More sharing options...
Johann Posted May 16, 2007 Report Share Posted May 16, 2007 question, i know that ihave to leave the tcv connected to the wire, and set the mbc at the psi that my remap has, but the ECu will not have problems at all?Sigh...Don't use an MBC on ME 7. Link to comment Share on other sites More sharing options...
