bullittandy Posted May 13, 2007 Report Share Posted May 13, 2007 I started to replace the front control arm bushings in my 01 V70. I chose to replace the bushings as opposed to the entire control arm because both are available and replacing just the bushings saves you $85-$150 per side depending on the source. However- It is impossible to replace the bushings!I have replaced suspension bushings in several cars ansd so have experience but the design of the control arm does not allow for successful bushing replacement. The forward bushing on each side has a thin metal shell which collapses on insertion (even after freezing it for several days to contract it) and this bushing must be precisely located (depthwise) in the control arm in order to be bolted in. Replace the entire control arm-its worth it. Link to comment Share on other sites More sharing options...
Chilled man Posted May 13, 2007 Report Share Posted May 13, 2007 ? lower control arm is only $40.00 and takes ten minutes to replace then you have to get the front end realigned .Explain becasue I am a little lost one what your saying ;) Link to comment Share on other sites More sharing options...
Guest Guest_bullittandy_* Posted May 14, 2007 Report Share Posted May 14, 2007 ? lower control arm is only $40.00 and takes ten minutes to replace then you have to get the front end realigned .Explain becasue I am a little lost one what your saying I priced front control arms for a 2001 V70 at $125 (FCP) to $285 (local dealer).Basically, the control arm forward bushings are not replaceable even though they sell them separate. Link to comment Share on other sites More sharing options...
Chilled man Posted May 14, 2007 Report Share Posted May 14, 2007 I priced front control arms for a 2001 V70 at $125 (FCP) to $285 (local dealer).Basically, the control arm forward bushings are not replaceable even though they sell them separate.just checked my last recipt got mine for the 01 for $60.00 for 1 while down there I would replace the lower ball joint also since that went out I had to replace the lower control arm also . not a pleasent to say the least there around 40-50 a peice try daryl waltrip honda volvo from Tennese ask for jamie tell him justin sent you :) Link to comment Share on other sites More sharing options...
TEKVOLVO Posted May 17, 2007 Report Share Posted May 17, 2007 I priced front control arms for a 2001 V70 at $125 (FCP) to $285 (local dealer).Basically, the control arm forward bushings are not replaceable even though they sell them separate.i've pressed in boat loads of thoes bushings Link to comment Share on other sites More sharing options...
