cicatriz Posted May 20, 2007 Report Share Posted May 20, 2007 I was told by a mechanic friend of mine that the cats on newer cars are a lot more efficient and better made than on the older ones, and that removing the cat on my car might actually hurt performance.This true?I'm getting a 3" dp built soon and was wondering whether I should go catless or not, if it'll be worth it and how loud it'll be, etc.Car is a 2005 S40 T5. Link to comment Share on other sites More sharing options...
JCviggen Posted May 20, 2007 Report Share Posted May 20, 2007 It wouldnt hurt performance but your will throw a code and go into limp mode or something unless you trick the rear O2 sensor. I wouldnt go catless in your case. Link to comment Share on other sites More sharing options...
cicatriz Posted May 20, 2007 Author Report Share Posted May 20, 2007 It wouldnt hurt performance but your will throw a code and go into limp mode or something unless you trick the rear O2 sensor. I wouldnt go catless in your case.I was gonna use an "O2 Sensor Spacer" or whatever you wanna call it. JHEII showed it to me on iPD website and said it should work.If not, will a high flow cat still be better than my current one? Or will that throw a code as well.With a new high flow cat where should the O2 bung go, right in the cat like on stock? or after it. Link to comment Share on other sites More sharing options...
JCviggen Posted May 20, 2007 Report Share Posted May 20, 2007 High flow cat should work without issues I've been running catless 3" on my 850 for a few years now. The sound is great, but you do get more unpleasant exhaust smells. Link to comment Share on other sites More sharing options...
cicatriz Posted May 20, 2007 Author Report Share Posted May 20, 2007 High flow cat should work without issues I've been running catless 3" on my 850 for a few years now. The sound is great, but you do get more unpleasant exhaust smells.Thanks; where would the O2 sensor that is located directly on the stock cat go on the new DP? Would it go on the new cat as well (the bung is located in the middle of the old cat) or would it come after the cat?Would a 3" Dp without a tune (say stage 3 bsr) pose any problems or its just going to give me more power, but not as much as it would with the tune. Link to comment Share on other sites More sharing options...
GShyneDM Posted May 20, 2007 Report Share Posted May 20, 2007 put the 2nd o2 after the cat.I havent had any issues with it placed there just need an extension cord Link to comment Share on other sites More sharing options...
Legbend Posted May 20, 2007 Report Share Posted May 20, 2007 Where are you getting it built? Link to comment Share on other sites More sharing options...
cicatriz Posted May 20, 2007 Author Report Share Posted May 20, 2007 Where are you getting it built?place in cutler ridge, miami; miami mufflerclosest place to me with a mandrel bender Link to comment Share on other sites More sharing options...
Auburn T5 Posted June 8, 2007 Report Share Posted June 8, 2007 not sure if you've had this done or not but do your ears a favor and get a race cat or something. It'll be retarded loud if you go catless. I just got mine put on and even with a magnaflow race cat and muffler, still a loud drone in the car.http://volvospeed.com/vs_forum/index.php?showtopic=78019 Link to comment Share on other sites More sharing options...
Karlson Posted June 8, 2007 Report Share Posted June 8, 2007 not sure if you've had this done or not but do your ears a favor and get a race cat or something. It'll be retarded loud if you go catless. I just got mine put on and even with a magnaflow race cat and muffler, still a loud drone in the car.http://volvospeed.com/vs_forum/index.php?showtopic=78019I really doubt that that s40 will be outrageous loud, as long as you can trick second o2 sensor, then go catless. I don't know a lot about new s40's, but I doubt that the spacer will work. it doesn't work for majority of 850/x70 Link to comment Share on other sites More sharing options...
Auburn T5 Posted June 8, 2007 Report Share Posted June 8, 2007 Mine has a cat and it's loud. I would QUICKLY grow weary of the noise if it didn't have that cat helping quiet things down. Link to comment Share on other sites More sharing options...
maiku Posted June 8, 2007 Report Share Posted June 8, 2007 but you can shoot flames... Link to comment Share on other sites More sharing options...
Gioseppe Posted June 8, 2007 Report Share Posted June 8, 2007 but you can shoot flames...only with speedtuning bwahaha Link to comment Share on other sites More sharing options...
maiku Posted June 8, 2007 Report Share Posted June 8, 2007 intimidation: +6hp +2tq Link to comment Share on other sites More sharing options...
theForgottenone Posted June 8, 2007 Report Share Posted June 8, 2007 I really doubt that that s40 will be outrageous loud, as long as you can trick second o2 sensor, then go catless. I don't know a lot about new s40's, but I doubt that the spacer will work. it doesn't work for majority of 850/x70I still have first OEM cat on my car and it's already loud. I can get you a clip of the older S40 with open DP, it sound like a boat. It's true that newer car OEM cat is more efficient.I would get a race cat. The gain of going catless is not enough to deal with the drone and the loudness :) Link to comment Share on other sites More sharing options...
