Gioseppe Posted June 8, 2007 Report Share Posted June 8, 2007 I still have first OEM cat on my car and it's already loud. I can get you a clip of the older S40 with open DP, it sound like a boat. It's true that newer car OEM cat is more efficient.I would get a race cat. The gain of going catless is not enough to deal with the drone and the loudness add another muffler :rolleyes: Link to comment Share on other sites More sharing options...
theForgottenone Posted June 8, 2007 Report Share Posted June 8, 2007 add another muffler What is the gain of going catless?I would say less than 5bhp. If you truly trying to gain 5bhp from going catless...might as well upgrade something else. Not to mention the environment factor. Link to comment Share on other sites More sharing options...
Gioseppe Posted June 8, 2007 Report Share Posted June 8, 2007 What is the gain of going catless?I would say less than 5bhp. If you truly trying to gain 5bhp from going catless...might as well upgrade something else. Not to mention the environment factor.lol. less backpressure and you wouldn't have to worry about it failing/clogging if its not there.also, stop benchracing plz. Link to comment Share on other sites More sharing options...
2001T5 Posted June 8, 2007 Report Share Posted June 8, 2007 Save yourself the hassle and put a Cat on it... Having to redo work because you left it off for +/-5 hp is just retarded. Link to comment Share on other sites More sharing options...
Auburn T5 Posted June 8, 2007 Report Share Posted June 8, 2007 add 1/8 psi to compensate for added cat. Link to comment Share on other sites More sharing options...
theForgottenone Posted June 8, 2007 Report Share Posted June 8, 2007 lol. less backpressure and you wouldn't have to worry about it failing/clogging if its not there.also, stop benchracing plz.FYI, S40 engine is exactly the same as 2.3L T5 engine except in 4cyl config. I dont' quote benchracing stats.You be the judge on how much gain going catless on 3" DP/exhaust system...Below is for open DPOpen DP dyno gain Link to comment Share on other sites More sharing options...
Auburn T5 Posted June 11, 2007 Report Share Posted June 11, 2007 I know the original poster has a 4 cylinder engine but I'd be willing to bet that the 5 cylinder engine and 4 bangers are completely different when it come to back pressure and power gains with catted vs catless dp/exhaust. Link to comment Share on other sites More sharing options...
grnmachine02 Posted June 14, 2007 Report Share Posted June 14, 2007 I know the original poster has a 4 cylinder engine but I'd be willing to bet that the 5 cylinder engine and 4 bangers are completely different when it come to back pressure and power gains with catted vs catless dp/exhaust.+1 for this guy.....and why did he have to drag the enviorment into this? he and al gore must be good friends Link to comment Share on other sites More sharing options...
KJ-R Posted June 25, 2007 Report Share Posted June 25, 2007 unless you trick the rear O2 sensor.is it the one was in the mid of the CAT??can we trick it by zip tie it to a frame?? Link to comment Share on other sites More sharing options...
KJ-R Posted June 25, 2007 Report Share Posted June 25, 2007 only with speedtuning bwahahado u mean ECU upgrades?? Link to comment Share on other sites More sharing options...
850drag Posted June 25, 2007 Report Share Posted June 25, 2007 you should be able to put a resistor in the second o2 wiring which will trick it to seeing consistent voltage when you dont have a cat. I am in the process of playing around with something like that. Link to comment Share on other sites More sharing options...
Gioseppe Posted June 25, 2007 Report Share Posted June 25, 2007 you should be able to put a resistor in the second o2 wiring which will trick it to seeing consistent voltage when you dont have a cat. I am in the process of playing around with something like that.OR have a chiptuner delete the rear 02 programming and be done with it?and btw, consistent voltage still sets o2 sensor codes... what do you think happens when an o2 sensor goes dead and idles at 400mV? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted June 25, 2007 Report Share Posted June 25, 2007 Personally, I just used an o2 spacer under the rear o2... I'm catless and it works great. Link to comment Share on other sites More sharing options...
Auburn T5 Posted June 25, 2007 Report Share Posted June 25, 2007 8 cents worth of wiring, some electrical tape and 20 minutes of my time was all I needed to take care of the rear 02 sensor.Clip wires, attach longer wire, tape up, insert sensor into cat. Fin. Link to comment Share on other sites More sharing options...
Zulu Posted June 25, 2007 Report Share Posted June 25, 2007 Well since a lb of boost is giving less then 10whp generally, 2-5whp is a nice gain. I told you Matt, just ziptie it to the frame. Link to comment Share on other sites More sharing options...
