sion Posted May 24, 2007 Report Share Posted May 24, 2007 Hello allAfter a myriad of to-ing & fro-ing between Volvo dealers & other parts suppliers, I am told the hose I need to replace which is pictured doesn't seem to exist!Volvo here in Oz say it's a non-genuine IAC with a non-genuine upper hose fitted. What the? The listed replacement hose on VADIS is approx 4 times the length & has an extra bend in it. I have this exact set-up on both my 850's (MY 95 & 96) including the pic attached of a '99 C70 with the very same hose fitted.Can anyone enlighten me on this puzzling issue? Link to comment Share on other sites More sharing options...
sion Posted May 24, 2007 Author Report Share Posted May 24, 2007 Whoops, I've now highlighted the said hose...HELP! Link to comment Share on other sites More sharing options...
RedTurbo850 Posted May 24, 2007 Report Share Posted May 24, 2007 I just checked my car, and I don't have that hose.And it's pretty crowded from the IAC cover to the radiator. The piping takes up quite a bit of space, and there is pretty much no way that whatever piping you have circled there would fit in my car, or at least it would fit so easily.Maybe it's a US/Euro or Australia thing? It's different in the two countries? Link to comment Share on other sites More sharing options...
BlackT5 Posted May 24, 2007 Report Share Posted May 24, 2007 I just checked my car, and I don't have that hose.And it's pretty crowded from the IAC cover to the radiator. The piping takes up quite a bit of space, and there is pretty much no way that whatever piping you have circled there would fit in my car, or at least it would fit so easily.Maybe it's a US/Euro or Australia thing? It's different in the two countries?You do have that hose. It's under the throttle body cover...and to the original poster....yes, that looks like the standard OEM AIC setup. Link to comment Share on other sites More sharing options...
T-5Bandit Posted May 24, 2007 Report Share Posted May 24, 2007 Mine needs replacing as well. Does anyone know the part number for the hose? Link to comment Share on other sites More sharing options...
BlackT5 Posted May 24, 2007 Report Share Posted May 24, 2007 I can look it up tonight if nobody beats me to it. Link to comment Share on other sites More sharing options...
T-5Bandit Posted May 24, 2007 Report Share Posted May 24, 2007 I can look it up tonight if nobody beats me to it.Cool, thanks. :D Link to comment Share on other sites More sharing options...
sion Posted May 24, 2007 Author Report Share Posted May 24, 2007 I can look it up tonight if nobody beats me to it.Yes please BlackT5! A part # would be great. I've checked with FCP Groton & they were searching for a part # for this hose too.Glad to hear this hose is indeed a factory unit... Link to comment Share on other sites More sharing options...
turbormonkey Posted May 25, 2007 Report Share Posted May 25, 2007 Yes please BlackT5! A part # would be great. I've checked with FCP Groton & they were searching for a part # for this hose too.Glad to hear this hose is indeed a factory unit...The part number is 9146225It has been covered in this thread http://volvospeed.com/vs_forum/index.php?s...p;mode=threadedAll you have to do is search Haha Link to comment Share on other sites More sharing options...
sion Posted May 25, 2007 Author Report Share Posted May 25, 2007 The part number is 9146225It has been covered in this thread http://volvospeed.com/vs_forum/index.php?s...p;mode=threadedAll you have to do is search HahaGood work, thanks for that Turbomax. ;) Link to comment Share on other sites More sharing options...
AU850T Posted May 25, 2007 Report Share Posted May 25, 2007 I had the same situation. Ordered the hose from the dealer and it looked way too long. Dealer ordered another and it came in the same. They finally got a tech to look at it and he said I had to cut the hose to fit. Brought it home and took the old one off, lined it up and cut it off. Fit fine and has worked fine for 2 years now. Link to comment Share on other sites More sharing options...
sion Posted May 25, 2007 Author Report Share Posted May 25, 2007 I had the same situation. Ordered the hose from the dealer and it looked way too long. Dealer ordered another and it came in the same. They finally got a tech to look at it and he said I had to cut the hose to fit. Brought it home and took the old one off, lined it up and cut it off. Fit fine and has worked fine for 2 years now.Exactly, & this is the situation I've faced before & face again now. It appears the original spec hose has been superseded & replaced by the longer hose, unless anyone else can prove otherwise?I cut & shut the longer hose when I replaced the original short hose & it was a less than ideal fit which caused it to split at the vac tree. I'd prefer to put a generic reinforced hose on, but the differing diameters make this pretty tough. Link to comment Share on other sites More sharing options...
