xspoonx Posted May 29, 2007 Report Share Posted May 29, 2007 I am having trouble locating a place in the fire wall to drill a whole to run the power wire to the amp from the battery. I tried to follow the hood realease cable and that looks like the best bet that I can see so far. The porblem is that it still looks like it will be pretty difficult. I am wondering where other people ran the power wire. Link to comment Share on other sites More sharing options...
xspoonx Posted May 29, 2007 Author Report Share Posted May 29, 2007 Ok, so I finally found a spot after drilling a couple test holes. The first spot I tried was double layered. after I got thru the first wall there was another one about 3 inches further in. The next spot I tried I didn't run into the same proble but, it was the thickest fire wall I've ever drilled thru. I ended up going right behind the gauge cluster. Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 29, 2007 Report Share Posted May 29, 2007 Ok, so I finally found a spot after drilling a couple test holes. The first spot I tried was double layered. after I got thru the first wall there was another one about 3 inches further in. The next spot I tried I didn't run into the same proble but, it was the thickest fire wall I've ever drilled thru. I ended up going right behind the gauge cluster.If you have an auto, look for the spot where the clutch would have been.On a stick, I seem to remember a good spot behind the glove box... Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted May 29, 2007 Report Share Posted May 29, 2007 why not just use an existing grommet? Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 30, 2007 Report Share Posted May 30, 2007 why not just use an existing grommet?Now that you mention it, I think I did use an existing pass through behind the Glove Box.I seem to remember a pretty good sized opening and slicing a little slit in a about a 2 inch grommet. Long time ago. I might be thinking about a 145... Link to comment Share on other sites More sharing options...
