Hilton Posted June 3, 2007 Report Share Posted June 3, 2007 I just found out that my brake lights don't light up when I'm stopping. I've checked the fuse and I know that the petal switch is working because I can a.) shift out of park, and b.) hear it click in the console when I push down the petal.I think it's a pretty slim chance that ALL of my brake lamps burned out at the same time. The "bulb burned out" light in the dash wasn't on until I removed one of the bulbs to check it's filament. Now it is illuminated.The filament was fine by the way.Any suggestions other than "set the car on fire and push it into a river" would be appreciated. Link to comment Share on other sites More sharing options...
Mike_P Posted June 3, 2007 Report Share Posted June 3, 2007 It is the brake pedal switch. Just because you hear it click and you can shift doesn't mean it's working properly. Try resetting it (I think you pull it out all the way and then let the brake pedal ratchet it back in, you can search to make sure), if this doesn't work then you replace it, it's only like $35 from the dealer. I had the same problem last year and a new switch fixed everything. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted June 3, 2007 Report Share Posted June 3, 2007 It is the brake pedal switch. Just because you hear it click and you can shift doesn't mean it's working properly. Try resetting it (I think you pull it out all the way and then let the brake pedal ratchet it back in, you can search to make sure), if this doesn't work then you replace it, it's only like $35 from the dealer. I had the same problem last year and a new switch fixed everything.I agree it sounds like a brake pedal switch. Link to comment Share on other sites More sharing options...
Chilled man Posted June 3, 2007 Report Share Posted June 3, 2007 IPD has them for sale check the back of your newest color cat. :) Link to comment Share on other sites More sharing options...
Hilton Posted June 4, 2007 Author Report Share Posted June 4, 2007 Okay, I'll check it out. Thanks! Link to comment Share on other sites More sharing options...
303jrodt5 Posted June 4, 2007 Report Share Posted June 4, 2007 That click noise you are hearing is the Shiftlock Microswitch clicking in and out underneath the shifter assembly. Link to comment Share on other sites More sharing options...
Hilton Posted June 8, 2007 Author Report Share Posted June 8, 2007 The switch came in yesterday. Seriously, it took less than 5 minutes to replace. Now I've got brake lights.After I pulled out the old switch I was concerned because the old switch looked fine. I wish everything was this easy. Link to comment Share on other sites More sharing options...
