Revo Posted June 8, 2007 Report Share Posted June 8, 2007 Whenever I brake, the radio in my 98 V70 R fades to static. and then as soon I lift my foot of the brake it stops. Any ideas? Link to comment Share on other sites More sharing options...
ViperVette Posted June 8, 2007 Report Share Posted June 8, 2007 That is so weird! Maybe your rotors are magnetically charged and they are creating a E/M field that is enveloping your radio antenna! Link to comment Share on other sites More sharing options...
BEJinFBK Posted June 8, 2007 Report Share Posted June 8, 2007 If the brake lights and the antenna amp are grounded in the same place,that grounding point may have a problem. Link to comment Share on other sites More sharing options...
crazykn Posted June 9, 2007 Report Share Posted June 9, 2007 I remember there is a TSB about this issue... but it supposedly only affects AM radio. Looking at the TSB, i guess i was wrong, it was OPPOSITE of what u describe, in fact it is related to the rear brakes and its hub, where static electricity is building up and arcing... ... odd problemCheck the brake light wiring, especially around the antenna amplifier near the back of your wagon (on one of the side panels)... Link to comment Share on other sites More sharing options...
BEJinFBK Posted June 9, 2007 Report Share Posted June 9, 2007 If the brake lights and the antenna amp are grounded in the same place,that grounding point may have a problem.Check the ground point behind the rear left tail light cover.The left brake light, the third eye and the antenna amp all groundthere. Pull the bolt, check for a lousy connection. Reassemble. Link to comment Share on other sites More sharing options...
(n)A-GAME Posted June 9, 2007 Report Share Posted June 9, 2007 i have the same problem with AM radio and acceleration? go figure, i just change the channel Link to comment Share on other sites More sharing options...
Revo Posted June 9, 2007 Author Report Share Posted June 9, 2007 thx for all the tips,The problem seems to be at it's worse when it is very hot outside. Link to comment Share on other sites More sharing options...
info2x Posted June 10, 2007 Report Share Posted June 10, 2007 thx for all the tips,The problem seems to be at it's worse when it is very hot outside.If that's the case I'm going to say you have a bad ground like BEJinFBK said since hot weather would raise the resistance of a bad ground even further. Just my $.02 Link to comment Share on other sites More sharing options...
