MeanGreenSwedeMachine Posted June 8, 2007 Report Share Posted June 8, 2007 I've got a new conical 15g turbo and a 3in straight flange downpipe. I remember reading once that there is a way to get that to work? Also, how much would it cost to get the O2 bungs welded in? Thanks. Link to comment Share on other sites More sharing options...
POOKDIZZLE Posted June 8, 2007 Report Share Posted June 8, 2007 I've got a new conical 15g turbo and a 3in straight flange downpipe. I remember reading once that there is a way to get that to work? Also, how much would it cost to get the O2 bungs welded in? Thanks.Way to get it to work is to either buy a straight flange turbo or hack up your DP Bungs shouldn't cost more than $25 to weld in as long as you pre-drilled the holes, if not @$40. Link to comment Share on other sites More sharing options...
Boosted5cyl Posted June 8, 2007 Report Share Posted June 8, 2007 so a conical turbo will bolt to a straight flanged DP but an angled will not ? im guessing clearance is the issue here ? Link to comment Share on other sites More sharing options...
maiku Posted June 8, 2007 Report Share Posted June 8, 2007 so a conical turbo will bolt to a straight flanged DP but an angled will not ? im guessing clearance is the issue here ?noyou need straight outlet turbo to straight flanged dpconical outlet to conical dpangled outlet to angled dp.... Link to comment Share on other sites More sharing options...
Boosted5cyl Posted June 8, 2007 Report Share Posted June 8, 2007 ok cool man. thanks. Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted June 8, 2007 Author Report Share Posted June 8, 2007 Thanks. Link to comment Share on other sites More sharing options...
