Olive850 Posted June 22, 2007 Report Share Posted June 22, 2007 hows it going.. ihave a 1993 volvo 850 non turbo.. with about 110K... it would start off normally..warm up no problem then i would put the car in drive and go the edge of the driveway and it would stall out and now it wont start up at all... so i replaced the ignition coil on the side of the fender, the air mass flow sensor, the fuel pump, and the sensor behind the distributor like on the end of the valve cover..and no check engine light,... the only other thing is tat it smells like sulfur....does anyone know what tat can be..thanks Link to comment Share on other sites More sharing options...
1sciroccofahrer Posted June 22, 2007 Report Share Posted June 22, 2007 I don't want to ask a stupid question but, have you checked the battery and alternator? Link to comment Share on other sites More sharing options...
Olive850 Posted June 22, 2007 Author Report Share Posted June 22, 2007 i just did and they are both fine..the alternator is charging and the battery tested good ... its driving me crazy..could it be a vacuum line or something Link to comment Share on other sites More sharing options...
1sciroccofahrer Posted June 22, 2007 Report Share Posted June 22, 2007 When was the last time the fuel filter was replaced? Have you also checked the fuel pump relay? Link to comment Share on other sites More sharing options...
TM850R Posted June 22, 2007 Report Share Posted June 22, 2007 Smells like sulfur? Bad cat possibly? Thats the only thing that I can think of that would smell like that. I dont know if that could cause the car to stall though. If its clogged enough I guess it could. Link to comment Share on other sites More sharing options...
1sciroccofahrer Posted June 22, 2007 Report Share Posted June 22, 2007 You should take the battery to a Kragen, or Autozone, and get the cold cranking amps tested. Just to be sure. Volts aren't everything when it comes to the battery. Link to comment Share on other sites More sharing options...
Olive850 Posted June 22, 2007 Author Report Share Posted June 22, 2007 where is the fuel pump relay located in this car, and it could be the cat. but i think there is not enough air coming into the engine ..maybe causing the fuel not to burn.... Link to comment Share on other sites More sharing options...
TM850R Posted June 22, 2007 Report Share Posted June 22, 2007 where is the fuel pump relay located in this car, and it could be the cat. but i think there is not enough air coming into the engine ..maybe causing the fuel not to burn....Too much backpressure from a clogged cat or not enough back pressure from a bad cat? Sulfur smell is generally a cat problem. Cant say for sure that this is the only problem here though. Link to comment Share on other sites More sharing options...
Guest Guest_mark taylor_* Posted June 22, 2007 Report Share Posted June 22, 2007 Too much backpressure from a clogged cat or not enough back pressure from a bad cat? Sulfur smell is generally a cat problem. Cant say for sure that this is the only problem here though.This is an easy check, there's a plug in the exhaust down pipe from the header. Remove it and see if stalling stops. Not of caution, don't do this at 3 am your neighbors will hate you, car will be loud!!!!Have you checked the air filter and/or flexible air box lines for crimping? Again sulfur smell is more cat converter indicator. Let us know what you find. Link to comment Share on other sites More sharing options...
