Anthrpicdecadnce Posted July 15, 2007 Author Report Share Posted July 15, 2007 custom auto machine in weymouth mass. They have built many drag ready engines for many many years. they are chargin 700. Link to comment Share on other sites More sharing options...
Zappo Posted July 15, 2007 Report Share Posted July 15, 2007 what does a set of rods run ? along with this whole project in general ?Rods are $500 for the set. Labor cost on the engine is what kills you. Link to comment Share on other sites More sharing options...
Anthrpicdecadnce Posted July 15, 2007 Author Report Share Posted July 15, 2007 Rods are $500 for the set. Labor cost on the engine is what kills you.labor is free. on me... for me any way... Link to comment Share on other sites More sharing options...
stick70 Posted July 15, 2007 Report Share Posted July 15, 2007 labor is free. on me... for me any way...Thats really not bad, i only have to pay 170 to get mine bored and such. It helps a ton to do alot of it yourself on top of knowing people. Link to comment Share on other sites More sharing options...
Zappo Posted July 15, 2007 Report Share Posted July 15, 2007 labor is free. on me... for me any way...Wish I could, but my car is 1000 miles away. Link to comment Share on other sites More sharing options...
Auburn T5 Posted July 16, 2007 Report Share Posted July 16, 2007 Does any work on these T5 blocks have to be done? Or are they pretty stout and ready to just drop in forged components and be done?Is any honeing work needed on the cylinder walls?What work on the crank is needed or is the stock crank fairly capable of handling high HP? Link to comment Share on other sites More sharing options...
Zappo Posted July 16, 2007 Report Share Posted July 16, 2007 Does any work on these T5 blocks have to be done? Or are they pretty stout and ready to just drop in forged components and be done?Is any honeing work needed on the cylinder walls?What work on the crank is needed or is the stock crank fairly capable of handling high HP?Depends on how much power you want to generate. Rods are the weakest stock part. I believe pistons would be next on the list, but they are good for at least 400 HP, and I believe some people are running much higher with stock pistons. Link to comment Share on other sites More sharing options...
Auburn T5 Posted July 16, 2007 Report Share Posted July 16, 2007 For people who use different pistons, do they do so mainly for extra strenght or do they specifically order pistons with different tops to change the compression ratio? Link to comment Share on other sites More sharing options...
Zappo Posted July 16, 2007 Report Share Posted July 16, 2007 For people who use different pistons, do they do so mainly for extra strenght or do they specifically order pistons with different tops to change the compression ratio?Strength. No one really changes compression, they just run higher boost levels. :) Link to comment Share on other sites More sharing options...
NW T5R Posted July 16, 2007 Report Share Posted July 16, 2007 Strength. No one really changes compression, they just run higher boost levels. Almost no one.... Mine is being setup about a half point lower than stock. Also going long rod short piston as well. Link to comment Share on other sites More sharing options...
Auburn T5 Posted July 16, 2007 Report Share Posted July 16, 2007 Almost no one.... Mine is being setup about a half point lower than stock. Also going long rod short piston as well.What's the benefit to this change? Drawbacks? Link to comment Share on other sites More sharing options...
NW T5R Posted July 16, 2007 Report Share Posted July 16, 2007 On my setup lowering the compression will enable improved off idle behavior while enabeling higher boost levels to be run. Link to comment Share on other sites More sharing options...
Auburn T5 Posted July 16, 2007 Report Share Posted July 16, 2007 Are you doing anything with the flywheel? Link to comment Share on other sites More sharing options...
Anthrpicdecadnce Posted July 19, 2007 Author Report Share Posted July 19, 2007 I'd imagine our flywheels are pretty heavy. I mean it would explain the hideous response our engines have... Link to comment Share on other sites More sharing options...
Auburn T5 Posted July 19, 2007 Report Share Posted July 19, 2007 I'd imagine our flywheels are pretty heavy. I mean it would explain the hideous response our engines have...Yeah I'm wondering if that's just lag or the weight of the FW. Are there any alternatives? I don't think I've seen any aftermarket flywheels for our cars. Link to comment Share on other sites More sharing options...
