Volvo S60r Blow Off Valve Question.
  • Replies 31
from what I recall, it hasn't been a problem. you're going to run rich when you let off the gas, but it isn't a huge deal because you're not on the throttle. basically its thinking theres still that air there when its being vented to the atmosphere. (gives 'correct' amount of fuel for that air, yet it isn't there, so it runs rich)
hope that helps,
-Jackson
Yea thanks, I have an old hks ssqv sitting around and i figured i would make use of it. Just in case I do get an error code and decide to put the stock pipe back, how do i reset the ecu? I know in some cars you disconnect the battery for a couple minutes and it will reset is this the case with volvo's?
radio code for the radio/head unit. as a anti-theft feature you are required to put in a code. you can get it from your dealer. IT IS FREE!!! Don't let them tell you other wise.
i've had my Head unit out many times on my 04R and haven't needed a radio code. can't say for sure on a 05 but i'd assume all is well.
there are two fuses you can pull on a 04 to quickly clear out the battery juice in the system. 05+ changed them so not sure what to tell you other than pull the battery and let it sit for some time.
If you have a GT the car will shift differently than when you first started driving it. it has a adaptive tranny.
mike
