mikie Posted July 8, 2007 Report Share Posted July 8, 2007 So I followed Bay13, checked the fluid and everything before getting started. So the unistall went perfect, I'm just having a issue getting the caliper back on. The inner pad is attached to the caliper, the outer pad is in it's place all I gotta do now is slip the caliper over... but it doesn't fit. Did the caliper close, lock up whatever you call it? What do I do now? Thanks Link to comment Share on other sites More sharing options...
mikie Posted July 8, 2007 Author Report Share Posted July 8, 2007 okay so i have been searching and it seems like i must compress the piston. i don't have a clamp so i guess i will use something else... Link to comment Share on other sites More sharing options...
Oreo931 Posted July 8, 2007 Report Share Posted July 8, 2007 you have to compress the piston...i went to the hardware store and bought a C clamp, that worked like a charm...its funny, i had the exact same problem when following bay13's instructions too...maybe they should add that part in. Link to comment Share on other sites More sharing options...
mikie Posted July 8, 2007 Author Report Share Posted July 8, 2007 you have to compress the piston...i went to the hardware store and bought a C clamp, that worked like a charm...its funny, i had the exact same problem when following bay13's instructions too...maybe they should add that part in.They should for beginers like me After thinking about it tho, I felt somewhat stupid...lol Link to comment Share on other sites More sharing options...
Zappo Posted July 8, 2007 Report Share Posted July 8, 2007 It shouldn't take all that much force to compress the piston. I have done them with my hands before. Link to comment Share on other sites More sharing options...
mikie Posted July 9, 2007 Author Report Share Posted July 9, 2007 It shouldn't take all that much force to compress the piston. I have done them with my hands before.I actually found a clamp laying around, worked well. I didn't even try using my hands, I guess I was assuming it would take more foce to compress. Thanks. Link to comment Share on other sites More sharing options...
wmartinlsmith Posted July 9, 2007 Report Share Posted July 9, 2007 :ph34r: i have used a screwdriver before to close pistons... i just left the old pad on and worked that mofo back to get the clearence... worked like a charm Link to comment Share on other sites More sharing options...
MrWinkey Posted July 10, 2007 Report Share Posted July 10, 2007 It shouldn't take all that much force to compress the piston. I have done them with my hands before.Good Lord??....Have you ever ripped your pee pee off while urinating? Link to comment Share on other sites More sharing options...
Oreo931 Posted July 11, 2007 Report Share Posted July 11, 2007 Good Lord??....Have you ever ripped your pee pee off while urinating?HAHAHAHHAHAHAHAHAHAHAH:lol: Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted July 11, 2007 Report Share Posted July 11, 2007 Good Lord??....Have you ever ripped your pee pee off while urinating?only once, fortunately after that its no longer a problem. Link to comment Share on other sites More sharing options...
