md850 Posted July 15, 2007 Report Share Posted July 15, 2007 What do you mean? do the pistons move in the cylinder?if the rings are worn the pistons will move slightly sideways in the bore due the increased clearance. use your hand and push the piston sideways and see if it moves freely. ;) Link to comment Share on other sites More sharing options...
trance42 Posted July 16, 2007 Author Report Share Posted July 16, 2007 if the rings are worn the pistons will move slightly sideways in the bore due the increased clearance. use your hand and push the piston sideways and see if it moves freely. I pushed on them. #1 moved but barely moved. Is any movement to much? I don't guess its to much more work to replace piston rings. Link to comment Share on other sites More sharing options...
md850 Posted July 16, 2007 Report Share Posted July 16, 2007 I pushed on them. #1 moved but barely moved. Is any movement to much? I don't guess its to much more work to replace piston rings.if it barely moved it should be ok for now. when they are done they move easily. Link to comment Share on other sites More sharing options...
ACES70 Posted July 16, 2007 Report Share Posted July 16, 2007 You having zero knowledge trumps Edit. Link to comment Share on other sites More sharing options...
Gioseppe Posted July 18, 2007 Report Share Posted July 18, 2007 the tdc/ marks not lining up issue is something i've ran into before.... and it still confuses me. i set my motor to TDC on #1 and didn't worry about the marks on the oil pump.hit me up on aim (i'm rarely ever on anymore) and i'll share what more i know. Link to comment Share on other sites More sharing options...
trance42 Posted July 18, 2007 Author Report Share Posted July 18, 2007 the tdc/ marks not lining up issue is something i've ran into before.... and it still confuses me. i set my motor to TDC on #1 and didn't worry about the marks on the oil pump.hit me up on aim (i'm rarely ever on anymore) and i'll share what more i know.I have the issue with the timing marks strate now. Read this Post. http://volvospeed.com/vs_forum/index.php?s...c=79958&hl=Ill add you on aim and talk to you to get your thoughts. Link to comment Share on other sites More sharing options...
Gioseppe Posted July 18, 2007 Report Share Posted July 18, 2007 I have the issue with the timing marks strate now. Read this Post. http://volvospeed.com/vs_forum/index.php?s...c=79958&hl=Ill add you on aim and talk to you to get your thoughts.that thread is such garbage it's rediculous.lets chat on aim, i'm on a decent amount now that i can steal the laptop at the GF's house. Link to comment Share on other sites More sharing options...
md850 Posted July 19, 2007 Report Share Posted July 19, 2007 the tdc/ marks not lining up issue is something i've ran into before.... and it still confuses me. i set my motor to TDC on #1 and didn't worry about the marks on the oil pump.hit me up on aim (i'm rarely ever on anymore) and i'll share what more i know.you dont know why your timing marks are off but the thread is rediculous, go get a brain, read and learn something before you make stupid and dumb comments. you dont even know why your marks are off boobbrain. :blink: Link to comment Share on other sites More sharing options...
Gioseppe Posted July 19, 2007 Report Share Posted July 19, 2007 you dont know why your timing marks are off but the thread is rediculous, go get a brain, read and learn something before you make stupid and dumb comments. you dont even know why your marks are off boobbrain. you funny. Link to comment Share on other sites More sharing options...
md850 Posted July 19, 2007 Report Share Posted July 19, 2007 you funny.Your marks are off boobbrain because by default the manufacturer designed the engine to be timed at the crank at 10 deg BEFORE top dead center so that at high rpm the spark does not fire when the piston is halfway down the hole.You set yours at tdc without finding out why the marks are out so you will lose power at higher rpms. You are lucky it wasn't something to fawk up your engine. Next time dont play smartass, ask questions. :P Link to comment Share on other sites More sharing options...
Gioseppe Posted July 19, 2007 Report Share Posted July 19, 2007 Your marks are off boobbrain because by default the manufacturer designed the engine to be timed at the crank at 10 deg BEFORE top dead center so that at high rpm the spark does not fire when the piston is halfway down the hole.You set yours at tdc without finding out why the marks are out so you will lose power at higher rpms. You are lucky it wasn't something to fawk up your engine. Next time dont play smartass, ask questions. okay mister, you need to get it through your head that the IGNITION TIMING ON 850'S CANNOT BE MECHANICALLY ALTERED! wiether or not i set the crank 10deg btdc or at straight tdc it does nothing with the ignition timing WHAT SO EVER. it only changes the static cam timing which in theory would retard the cams -5 degrees each (if the crank was set at tdc, not 10 btdc) therefore giving up bottom end and allowing the engine to actually perform better at higher rpms! so instead of coming to this forum and acting like a complete giant know-it-all asshole that thinks he is right EVERY SINGLE TIME just realize that you might be wrong and that some people have a little more knowledge about these cars then the common shadetree mechanic. in end i would never ask you a question because i probably WOULD fuck up my engine. thanks for all the help so far! Link to comment Share on other sites More sharing options...
md850 Posted July 19, 2007 Report Share Posted July 19, 2007 okay mister, you need to get it through your head that the IGNITION TIMING ON 850'S CANNOT BE MECHANICALLY ALTERED! wiether or not i set the crank 10deg btdc or at straight tdc it does nothing with the ignition timing WHAT SO EVER. it only changes the static cam timing which in theory would retard the cams -5 degrees each (if the crank was set at tdc, not 10 btdc) therefore giving up bottom end and allowing the engine to actually perform better at higher rpms! so instead of coming to this forum and acting like a complete giant know-it-all asshole that thinks he is right EVERY SINGLE TIME just realize that you might be wrong and that some people have a little more knowledge about these cars then the common shadetree mechanic. in end i would never ask you a question because i probably WOULD monkey up my engine. thanks for all the help so far!who said anything about ignition timing?bonehead, can you read? I ACTUALLY agree that setting it at 5 deg btdc will actually improve performance for reasons stated in the thread. read and understand.READ THE THREAD, WHAT IS THE BEST CRANK TIMING.harse hole. Link to comment Share on other sites More sharing options...
md850 Posted July 19, 2007 Report Share Posted July 19, 2007 who said anything about ignition timing? can you read? I ACTUALLY agree that setting it at 5 deg btdc will actually improve performance for reasons stated in the thread. read and understand.and for your information, i am not always correct. i ask questions like everyone else. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 19, 2007 Report Share Posted July 19, 2007 More volvospeed pearls here too eh? Link to comment Share on other sites More sharing options...
ACES70 Posted July 19, 2007 Report Share Posted July 19, 2007 This ones been going for a couple of days now. Link to comment Share on other sites More sharing options...
