DARKSIDE Posted July 9, 2007 Report Share Posted July 9, 2007 Anyone on here use Race Gas....C-16, 110, etc.If you are, what ECU are you running, and is it tuned for it? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted July 9, 2007 Report Share Posted July 9, 2007 Yup, I have used it in the past, no real point unless you are seeing pre-ignition. Link to comment Share on other sites More sharing options...
DARKSIDE Posted July 9, 2007 Author Report Share Posted July 9, 2007 Yup, I have used it in the past, no real point unless you are seeing pre-ignition.what'd u mean by pre-ignition? Link to comment Share on other sites More sharing options...
grnmachine02 Posted July 9, 2007 Report Share Posted July 9, 2007 what'd u mean by pre-ignition?detonation/pinging, The fuel is igniting before the spark plug can ignite it. Not good. Torco makes Mach 104 unleaded race fuel. Link to comment Share on other sites More sharing options...
mAydAy Posted July 9, 2007 Report Share Posted July 9, 2007 Leaded gas is a little hard on oxygen sensors and catalytic converters also...I have used GT100 many times in several of my 850's. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 9, 2007 Report Share Posted July 9, 2007 Excess octane results in less mileage and HP but whatever Link to comment Share on other sites More sharing options...
hawks25 Posted July 9, 2007 Report Share Posted July 9, 2007 I've used GT100 with my base mapped RICA and have gained 3-4 mph in the 1/4 consistently. Boost goes from 17 (ish) to 19 psi in 3rd gear.I have no idea if it's pinging cause I don't have a reader yet (don't roll your eyes, Joe ), but if I'm pinging, then just about everyone else that is running an 17-18 psi base chip/MBC is too. Link to comment Share on other sites More sharing options...
thelostartof Posted July 10, 2007 Report Share Posted July 10, 2007 Excess octane results in less mileage and HP but whateverUnless you have a crappy rwd car like myself that gets better mpg on higher oct gas But then again for whatever reason there are a few engines out there that make more power on 87 than on the race gas they run at the track Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 10, 2007 Report Share Posted July 10, 2007 Unless you have a crappy rwd car like myself that gets better mpg on higher oct gas But then again for whatever reason there are a few engines out there that make more power on 87 than on the race gas they run at the trackLow compression, low boost, or low revs will all make more power on 87. 8:1 6k and 20 psi does fine on 94-95 octane in most climates. 110 you will loose HP and never tried 100 as I never have it around. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted July 10, 2007 Report Share Posted July 10, 2007 You mean that 95 octanes gas performs better to our cars than the 100?I've never seen a difference to the performance by using 100 octanes instead of 95.I just use it because of the better quality.But as I'have seen in past topics you and we here don't have the same types of gas. Link to comment Share on other sites More sharing options...
Patrickw Posted July 10, 2007 Report Share Posted July 10, 2007 DONT do this.. i burned out both O2 sensors in like 3 days with this idea :D Link to comment Share on other sites More sharing options...
thelostartof Posted July 10, 2007 Report Share Posted July 10, 2007 Low compression, low boost, or low revs will all make more power on 87. 8:1 6k and 20 psi does fine on 94-95 octane in most climates. 110 you will loose HP and never tried 100 as I never have it around.Then again those bike engines that make more power on 87 than race gas are all high compression, no boost, and high revs so ehotherwise i miss the way my car ran on 115 leaded ... so nice and smooth Link to comment Share on other sites More sharing options...
hawks25 Posted July 10, 2007 Report Share Posted July 10, 2007 DONT do this.. i burned out both O2 sensors in like 3 days with this idea Gotta stay away from leaded gas, mang. Around here 100 is unleaded and in some spots you can find 110 unleaded, but for the most part, anything over 100 is leaded. Which is bad for O2 sensors as you found out. :P Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 10, 2007 Report Share Posted July 10, 2007 Then again those bike engines that make more power on 87 than race gas are all high compression, no boost, and high revs so ehotherwise i miss the way my car ran on 115 leaded ... so nice and smoothProbably carburetors then with so so metering. High compression needs octane more than anything else. You can obviously fatten the A/F to do the same thing but I thought we were talking about performance here not backwoods 101 engine theory. Link to comment Share on other sites More sharing options...
thelostartof Posted July 10, 2007 Report Share Posted July 10, 2007 Probably carburetors then with so so metering. High compression needs octane more than anything else. You can obviously fatten the A/F to do the same thing but I thought we were talking about performance here not backwoods 101 engine theory.Actually they are the new fuel injected ITB engines on the 1000cc bikes ... but eh Link to comment Share on other sites More sharing options...
