Katron Posted July 14, 2007 Report Share Posted July 14, 2007 Using a feeler gauge, measure the air gap. It should be between 0.4mm and 0.8mm (0.016" and 0.031") for the Sanden compressor and between 0.3mm and 0.6mm (0.012" and 0.024") for the Seiko compressor. If it is too large, adjust it by following the procedure below.By the way, its most likely to be a Seiko compressor on your volvo.If you're interested, I have the complete overview on the a/c system. Its quite a large file, so I have to mail it to you. Just PM me your mail. Link to comment Share on other sites More sharing options...
Guest HKGeorge Posted July 18, 2007 Report Share Posted July 18, 2007 By the way, its most likely to be a Seiko compressor on your volvo.If you're interested, I have the complete overview on the a/c system. Its quite a large file, so I have to mail it to you. Just PM me your mail.Katron, How can I get a copy of the system overview?Thanks, Link to comment Share on other sites More sharing options...
Guest Stiggan, Sweden Posted July 18, 2007 Report Share Posted July 18, 2007 Katron, How can I get a copy of the system overview?Thanks,Hi!I have a similar problem with my Volvo 944 - 95. The compressor clutch works for a few seconds and then turns off some seconds, turns on and turns off, and so on, producing too little cold fluid or gas in the "cold circuit". Any suggestions on what to do?Stiggan Link to comment Share on other sites More sharing options...
xluke Posted August 10, 2007 Report Share Posted August 10, 2007 Hi!I have a similar problem with my Volvo 944 - 95. The compressor clutch works for a few seconds and then turns off some seconds, turns on and turns off, and so on, producing too little cold fluid or gas in the "cold circuit". Any suggestions on what to do?StigganHey Stiggan,I think that problem is just too low on refrigerant. Have someone give it a quick charge or get a kit at Autozone. ALSO: Does anyone know if the air gap procedure works on older seiko compressors ('94 940) ? I have what seems to be the same problem w/ my 940 wagon. I could use a write-up.Thanks a lot! Link to comment Share on other sites More sharing options...
S60RDUDE Posted August 10, 2007 Author Report Share Posted August 10, 2007 what about my problem Dont thread jack and your problem might have been solved I believe it is the clutch on my AC system I am going to remove a shim or two and see.Thanks, Link to comment Share on other sites More sharing options...
Tom R ii Posted August 11, 2007 Report Share Posted August 11, 2007 I just went through all of the clutch posts and then went out and measured the gap on my 1998 S70 w/165K miles...gap was larger than my largest feeler guage...in excess of 9mm!My problem is that it seems to require removal of the wheel and the inner fender liner? Is there any way to do it from on top w/o taking stuff apart? I can see how it is done...just can't get to it w/o removing wheel etc.I do not have time or good spot to work on...any other alternatives. Maybe take it to a non-Volvo dealer AC shop with the narrative and pics?Thanks for the help...Tom R in Two Harbnors, MN Link to comment Share on other sites More sharing options...
dfuerst Posted August 30, 2007 Report Share Posted August 30, 2007 If you're interested, I have the complete overview on the a/c system. Its quite a large file, so I have to mail it to you. Just PM me your mail.If it's possible, I'd like to get this file too, if it's not to much trouble. I have a 2001 XC70 that the A/C is acting up on.Thanks!Darren Link to comment Share on other sites More sharing options...
Guest Stiggan Posted September 17, 2007 Report Share Posted September 17, 2007 Hi!I have now examined the condensor by a UV lamp and it showed up to be a leakage where the tubes were coupled to the condensor. So it was a problem with too little refridgerant after all. Fortunately, the AC workshop fixed it as a warranty repair so I did not have to pay anything. I did also find out that a normal light lamp was useless but a LED lamp could be used as a UV lamp. Thank you for the reply xluke.Stiggan Link to comment Share on other sites More sharing options...
