fasteddyT5 Posted July 11, 2007 Report Share Posted July 11, 2007 ive got a 1998 s70 t5m with 110,000 miles. The clutch needs to replaced fairly soon and i was wondering what other maintenance items i should consider doing while the eninge is out of the car. I'm going to have the rear main seal done because it only costs a few bucks and all the labor is alreay done. I was thinking that i might have a few of the PITA pcv parts done as well with the enige out.Any other items i should get done?thanks Link to comment Share on other sites More sharing options...
(n)A-GAME Posted July 11, 2007 Report Share Posted July 11, 2007 maybe someone else will chime in here, but I have never heard of having to take the engine out to change a clutch. Link to comment Share on other sites More sharing options...
Boost3237 Posted July 11, 2007 Report Share Posted July 11, 2007 far easier then dropping the sub framewhile the motor is out, t-belt, water pump, rear main !!!! trust me it will help alot thats all i can really think of, i JUST as in this past sunday dropped my motor/tranny back into my new 850. Link to comment Share on other sites More sharing options...
bagodoosh Posted July 12, 2007 Report Share Posted July 12, 2007 we did:850R clutch/Pressure plate : 272218rear main seal : 9458178axle seals : 6843481 (x2)flywheel bolts : 9454743 (x10)pressure plate bolts : 959219 (x6)release bearing : 9181780oil return o-ring & gasket : 30637866 & 3514546those part#s are for external slave clutch cylinder (single-mass).make sure you get new bolts for the flywheel and pressure plate. they need to be replaced. Link to comment Share on other sites More sharing options...
