B737 Posted July 13, 2007 Report Share Posted July 13, 2007 I have a 2001 XC that has the fault message of "Tailgate open" all of the time even with it shut. The previous owner broke the glass and could not wait for the dealer to replace it so had a glass shop do it. The dealer said that the fault light appears due to the glass is not a Volvo/OEM part. It is a name brand window who's name escapes me right now. How exactly would the glass tie in to the door open system? Seems a little odd to me but you have to believe the dealer right?Any suggestions on where to start with this?Does anyone have access to the wiring diagram for the tailgate they could send me?Thanks,Jeremy Link to comment Share on other sites More sharing options...
Chilled man Posted July 13, 2007 Report Share Posted July 13, 2007 lol glass not volvo glass I would think when the glass was installed they disconnected a sensor in the trunk lid ? or the sensor telling you the trunk lid is closed went bad. Seriously how dumb does the dealer think some people are, what like volvos have some specials super glass in there cars that no one else has ? :lol: Link to comment Share on other sites More sharing options...
flyfishing3 Posted July 13, 2007 Report Share Posted July 13, 2007 just had this fixed in my car two weeks ago.you'll need a whole new wiring harness.there's a ton of wires that run through the trunk hinge and one of the wires was getting pinched and now has broke clean through.i watched my mech do it. not a huge deal but you have to remove the whole trunk inards and at least on my car most of the stuff on the drivers side under the hinge.he said its pretty common for wagons that use the trunk often.the part was under 200 iirc. i'm sure my part number would be different than what you need though.mike Link to comment Share on other sites More sharing options...
PyROTech Posted July 13, 2007 Report Share Posted July 13, 2007 just had this fixed in my car two weeks ago.you'll need a whole new wiring harness.there's a ton of wires that run through the trunk hinge and one of the wires was getting pinched and now has broke clean through.i watched my mech do it. not a huge deal but you have to remove the whole trunk inards and at least on my car most of the stuff on the drivers side under the hinge.he said its pretty common for wagons that use the trunk often.the part was under 200 iirc. i'm sure my part number would be different than what you need though.mikecan he not just cut and tape the wires back together on the pinch? Link to comment Share on other sites More sharing options...
flyfishing3 Posted July 13, 2007 Report Share Posted July 13, 2007 maybe, but this dumb wire that was cut throw was so thin. also you could tell the whole harness was wearing at this bend spot. in a pinch i'm sure you could jerry rig it. Link to comment Share on other sites More sharing options...
B737 Posted July 13, 2007 Author Report Share Posted July 13, 2007 lol glass not volvo glass I would think when the glass was installed they disconnected a sensor in the trunk lid ? or the sensor telling you the trunk lid is closed went bad. Seriously how dumb does the dealer think some people are, what like volvos have some specials super glass in there cars that no one else has ? I thought it seemed like a bunch of BS too, but some times you never know what they will do to keep you as a customer (hostage!). I'll take the cover off this weekend and poke around. FYI the glass is by PPG.Jeremy Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted July 14, 2007 Report Share Posted July 14, 2007 It could need a new tailgate latch too. Link to comment Share on other sites More sharing options...
B737 Posted July 16, 2007 Author Report Share Posted July 16, 2007 It could need a new tailgate latch too.dmelvi007- I read in another post your a tech. So what gives the signal to the "message" indicator that the hatch is open? I t/s it today and found the micro switch in the latch open all the time. Cleaned and cycled it now it works fine (the switch). Getting .03 ohms thru the plug when locked and open when not. Put it all back together and still getting the message. Is there another proximity sensor hidden in the frame that senses the hatch being closed or is it just through that switch? If it's thru the switch then I must have a open wire upstream of the connector.Thanks,Jeremy Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted July 17, 2007 Report Share Posted July 17, 2007 dmelvi007- I read in another post your a tech. So what gives the signal to the "message" indicator that the hatch is open? I t/s it today and found the micro switch in the latch open all the time. Cleaned and cycled it now it works fine (the switch). Getting .03 ohms thru the plug when locked and open when not. Put it all back together and still getting the message. Is there another proximity sensor hidden in the frame that senses the hatch being closed or is it just through that switch? If it's thru the switch then I must have a open wire upstream of the connector.Thanks,JeremyJust through the switch. Sounds like the wiring harness is what you need. I just brought up the latch because I have replaced a harness and not had the message go away. Be sure to eliminate all options before replacing a part, good job. Link to comment Share on other sites More sharing options...
B737 Posted July 17, 2007 Author Report Share Posted July 17, 2007 Just through the switch. Sounds like the wiring harness is what you need. I just brought up the latch because I have replaced a harness and not had the message go away. Be sure to eliminate all options before replacing a part, good job.Thanks for the info. I'll look for the open wire connection tonight.Jeremy Link to comment Share on other sites More sharing options...
flyfishing3 Posted July 17, 2007 Report Share Posted July 17, 2007 i guess me telling you the harness right away i'm just chop liver. hope you find it. the one i had cut was a thin pinky colored wire. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted July 18, 2007 Report Share Posted July 18, 2007 i'm just chop liver. That goes without saying. :P Link to comment Share on other sites More sharing options...
B737 Posted July 18, 2007 Author Report Share Posted July 18, 2007 Well after spending a hour or so of tracing wires and jumpering I finally figured it out. It did turn out to be directly related to the glass after all!!! The glass has three connectors on it: Power in +12vdc, ground and another ground tap. I found no (as in broken off) tab attached to the glass for the ground. (This is why I never like to have some one else work on my cars. They broke it when installing it and rather than do the right thing for the customer and getting a new window $$$ they just covered it up!) So this winter I would have figured out that I also have no window heat. The other ground tap is the source for the ground signal to the computer through the micro switch in the latch, when closed. So no ground for the window= no ground for switch = fault message.I was able to make a spring contact for the ground to the glass as solder would not stick to the traces. Then I found that the trace for the ground tab to the switch was also open so had to add an extra wire across the hatch to the connector for the switch. IMO poor design to use a trace in the glass rather than a wire to cross the hatch.Put it all back together and no message and window heat!!Also learned that the entire hatch is fiberglass.Thanks for the help and info,Jeremy Link to comment Share on other sites More sharing options...
