jonsayre Posted July 17, 2007 Report Share Posted July 17, 2007 I am in the final stages of my long lost volvo project and want to delete the charcoal canister. I know this question has been brought up before but how do you do it? I tried a search with no luck. I have a 99 S-70 GLT. Any HELP is appreciated. Thanks! Link to comment Share on other sites More sharing options...
Oreo931 Posted July 17, 2007 Report Share Posted July 17, 2007 Wont you not pass inspection if you do this? Link to comment Share on other sites More sharing options...
BlackT5 Posted July 17, 2007 Report Share Posted July 17, 2007 Are you using a stand alone ecu?I left mine connected to the purge valve, but the purge valve is disconnected from the electrical sensor and vacuum lines to the intake. Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted July 17, 2007 Report Share Posted July 17, 2007 why would you want to delete it? Link to comment Share on other sites More sharing options...
BlackT5 Posted July 17, 2007 Report Share Posted July 17, 2007 i'm assuming he's using a stand alone so unless you setup the ecu to purge, you gotta decide what you want to do with it.Some people remove the canister and vent the tank, some just vent the canister line open under the car. Link to comment Share on other sites More sharing options...
jonsayre Posted July 17, 2007 Author Report Share Posted July 17, 2007 The reason I want to delete it is because it is full of sooty oil residue, the previous owner must not have done oil changes the turbo got cooked and I beleive the oil was coking (I beleive that is the right term) essentially cooking and becoming thick and pasty. I am not running stand alone just want to delete this thing that seems useless to me. There is a large port on the side of the block and another just above it on the side of the block they both run into the canister, can I simply plug them both or loop them together. Then do the same with all the other hoses on top of the canister? I really appreciate the help, I will post pics as soon as I figure out how to. Link to comment Share on other sites More sharing options...
BlackT5 Posted July 17, 2007 Report Share Posted July 17, 2007 lol. You're referring to the PCV system. Just replace the box with a new one or clean it out. You can also look into installing a catch can. Link to comment Share on other sites More sharing options...
Oreo931 Posted July 17, 2007 Report Share Posted July 17, 2007 lol. You're referring to the PCV system. Just replace the box with a new one or clean it out. You can also look into installing a catch can.ohhhh, lol.You need your PCV system. They tend to get clogged after a while and cause excess pressure in the system. You should look into replacing all of the components. FCP Groton (www.fcpgroton.com) sells a PCV kit for our cars. There is also tons of info on this site on how to replace this yourself. Link to comment Share on other sites More sharing options...
