giantrobot9000 Posted July 22, 2007 Report Share Posted July 22, 2007 I changed my plugs today with Champions from NAPA,and then went out for a drive to see if there was a difference.It seems a little smoother,but the thing that I noticed the most was some white exhaust smoke while I was sitting at the drive-thru.I had just taken a hard run at full throttle on the highway,though,so I'm thinking this is really the reason.My car has never smoked before,though.Carbon deposits clearing out maybe? I had also just added a quart of oil,as I was low.I bought some Seafoam,but I'm kinda scared to use it because the car actually runs pretty well for such high mileage (297k).I've been putting off doing the PCV system,too,which it probably needs.If I Seafoam into the intake,do you think it would help me or harm me? Link to comment Share on other sites More sharing options...
Dmsee Posted July 22, 2007 Report Share Posted July 22, 2007 Shitty plugs ;) Link to comment Share on other sites More sharing options...
giantrobot9000 Posted July 22, 2007 Author Report Share Posted July 22, 2007 Shitty plugs You think the plugs alone caused it? I wanted to give them a try before I paid $32 for the OEM plugs because some folks said they were fine for them. Link to comment Share on other sites More sharing options...
James100 Posted July 22, 2007 Report Share Posted July 22, 2007 My original 1994 "Volvo manual" that comes with the car when you buy it says for a turbo Champion RC7GYC(or equivalent). Where the 7 is They changed it to 9 I believe. Spark plug gap .028I put these Champions in and my car runs better with them than the Bosch copper. Make sure the gap is correct. Link to comment Share on other sites More sharing options...
James100 Posted July 22, 2007 Report Share Posted July 22, 2007 What kind of car you talking about here? Turbo or NA? Link to comment Share on other sites More sharing options...
Dmsee Posted July 22, 2007 Report Share Posted July 22, 2007 Id say turbo just because of $32 OEM plugs B) Link to comment Share on other sites More sharing options...
giantrobot9000 Posted July 22, 2007 Author Report Share Posted July 22, 2007 Yeah,94 850 Turbo.The plugs are gapped to .028. Link to comment Share on other sites More sharing options...
MrWinkey Posted July 23, 2007 Report Share Posted July 23, 2007 I had also just added a quart of oil,as I was low.Are you sure it was low? Perhaps now it may be a bit over full resulting in your smoke Link to comment Share on other sites More sharing options...
giantrobot9000 Posted July 23, 2007 Author Report Share Posted July 23, 2007 There's more......on the way home last night,my car lost power and I saw a big plume of black smoke out the exhaust.Turned out an intercooler hose popped off again (the t shaped one I replaced).I tighten it back up and keep driving,but when I got into the throttle just a little bit,it immediately started making boost and the needle went WAY over to the right....much further than normal.This wasn't even more than 3/4 throttle! It did this two times and then went back to normal.Was that the computer resetting itself or something? I kinda miss it! :D Link to comment Share on other sites More sharing options...
