giantrobot9000 Posted July 22, 2007 Report Share Posted July 22, 2007 So these seem to riveted in.I'm missing one and the others are faded or loose.I really want to at least remove them,and possibly put new ones on before winter.How can I take these off without damaging whatever they are attached to? (94 850 turbo wagon,btw) Link to comment Share on other sites More sharing options...
Oreo931 Posted July 22, 2007 Report Share Posted July 22, 2007 So these seem to riveted in.I'm missing one and the others are faded or loose.I really want to at least remove them,and possibly put new ones on before winter.How can I take these off without damaging whatever they are attached to? (94 850 turbo wagon,btw)You can use pliers or cutting pliers to manuever them out. Then go to any hardware store and buy a rivet gun. They are liek $15-$20 for a gun with rivets. Link to comment Share on other sites More sharing options...
Dmsee Posted July 22, 2007 Report Share Posted July 22, 2007 To take them off just use a drill and drill them out and then follow Adams response Link to comment Share on other sites More sharing options...
MrWinkey Posted July 23, 2007 Report Share Posted July 23, 2007 I cut the heads off with side cutters if needed then punch the rest of the rivet back into the fenderwell. Volvo sells the rivets called "blind rivets" they are nice and have the big plastic end on them . You will need a rivet gun though Link to comment Share on other sites More sharing options...
drive28 Posted July 23, 2007 Report Share Posted July 23, 2007 As MrWinkey said....try a cutting the head off with a side cutter or use a dremel drill with a cutting wheel to cut the head off or whittle it down enough to poke the rivet back through.. Sometimes when you try to drill them out and they are embedded into something soft like the ABS plastic fenderwell liner/splash guards they will just spin.......If you still have the front drivers side mud flap and you intend on replacing it I might be interested in it if it is salvagable. My son's 850 is missing just that one on the front of his car......he is a financially strapped college student and always looking for an "organ donor"Cheers,Fred Link to comment Share on other sites More sharing options...
giantrobot9000 Posted July 23, 2007 Author Report Share Posted July 23, 2007 As MrWinkey said....try a cutting the head off with a side cutter or use a dremel drill with a cutting wheel to cut the head off or whittle it down enough to poke the rivet back through.. Sometimes when you try to drill them out and they are embedded into something soft like the ABS plastic fenderwell liner/splash guards they will just spin.......If you still have the front drivers side mud flap and you intend on replacing it I might be interested in it if it is salvagable. My son's 850 is missing just that one on the front of his car......he is a financially strapped college student and always looking for an "organ donor"Cheers,FredI do have that one.I'm missing the passenger side front.If it comes off ok,I'll let you know and you can have it. Link to comment Share on other sites More sharing options...
drive28 Posted July 23, 2007 Report Share Posted July 23, 2007 I do have that one.I'm missing the passenger side front.If it comes off ok,I'll let you know and you can have it.Thanks! If you need to borrow a rivet gun I have an old one I could mail up to you. USPS from Massachusetts to Maine is not more than 2 days.Cheers,FRED Link to comment Share on other sites More sharing options...
Yellow95 Posted July 23, 2007 Report Share Posted July 23, 2007 I put mine back on with plastic clips. I always do that with my wheel well skirts in case I need to get back in there for something.Gary Link to comment Share on other sites More sharing options...
