Owned Posted July 23, 2007 Report Share Posted July 23, 2007 Can someone pshop what these would look like on an 850 non-yakazi cluster? If it doesnt look bad I want to buy a set of these.IMO you should pickup a Yazaki cluster. Once I'm done with all my testing for the guages, I can test both of mine to check they work and I'll sell you whichever one I don't use. I figure if it works in my '95 then it should work in yours, unless yours is OBD-II. Link to comment Share on other sites More sharing options...
Oreo931 Posted July 23, 2007 Report Share Posted July 23, 2007 IMO you should pickup a Yazaki cluster. Once I'm done with all my testing for the guages, I can test both of mine to check they work and I'll sell you whichever one I don't use. I figure if it works in my '95 then it should work in yours, unless yours is OBD-II.I'm down.My T5R has the OBDII port under the ashtray, but also has the diagnostics box in the engine bay. Will it still work? Link to comment Share on other sites More sharing options...
Owned Posted July 24, 2007 Author Report Share Posted July 24, 2007 I'm down.My T5R has the OBDII port under the ashtray, but also has the diagnostics box in the engine bay. Will it still work?Plug in an OBDII scanner and find out. ;) Link to comment Share on other sites More sharing options...
Oreo931 Posted July 24, 2007 Report Share Posted July 24, 2007 No i can read codes w/ a scanner...im asking if the yakazi will work Link to comment Share on other sites More sharing options...
Owned Posted July 24, 2007 Author Report Share Posted July 24, 2007 No i can read codes w/ a scanner...im asking if the yakazi will workIf your car can read OBDII codes, not just OBDI or 1.5, then AFAIK you can run an s70 cluster. If not, you have to use the Yazaki. Link to comment Share on other sites More sharing options...
Oreo931 Posted July 24, 2007 Report Share Posted July 24, 2007 will the yakazi work either way? if so then id rather do that instead of taking a chance... Link to comment Share on other sites More sharing options...
Owned Posted July 24, 2007 Author Report Share Posted July 24, 2007 will the yakazi work either way? if so then id rather do that instead of taking a chance...I really doubt it. I don't understand how you're taking a chance, though. Just go try to read throttle position through the OBD port. If you can, buy and S70 cluster, if you can't buy a Yazaki. Pretty cut and dry? Link to comment Share on other sites More sharing options...
Oreo931 Posted July 24, 2007 Report Share Posted July 24, 2007 A throttle position? I can read codes through the OBDII port... Link to comment Share on other sites More sharing options...
Owned Posted July 24, 2007 Author Report Share Posted July 24, 2007 Go to autozone and borrow an OBDII scanner. Link to comment Share on other sites More sharing options...
Oreo931 Posted July 24, 2007 Report Share Posted July 24, 2007 I HAVE ONE!!!i have a code reader...not a scanner...is there a difference? Link to comment Share on other sites More sharing options...
Owned Posted July 24, 2007 Author Report Share Posted July 24, 2007 i have a code reader...not a scanner...is there a difference?Yes. If you can't read throttle position or engine load go get a scanner from autozone. If you still can't read it then you don't have OBDII! Link to comment Share on other sites More sharing options...
Oreo931 Posted July 24, 2007 Report Share Posted July 24, 2007 thanks,now you made me look like a huge by making this into its own seperate thread! Link to comment Share on other sites More sharing options...
Owned Posted July 24, 2007 Author Report Share Posted July 24, 2007 I didn't want a bunch of OT posts in the other one. Besides, I made it look like I'm the OP. :P Link to comment Share on other sites More sharing options...
Oreo931 Posted July 24, 2007 Report Share Posted July 24, 2007 I didn't want a bunch of OT posts in the other one. Besides, I made it look like I'm the OP. oh yea LOL fine. you are the btw, r u coming to t3m m337? Link to comment Share on other sites More sharing options...
