Chilled man Posted August 2, 2007 Report Share Posted August 2, 2007 And the dealer has no clue why ETS light was on and was throwing the code for Dead ETM so had them change that out $600.00 drive it for a day light comes back on and its has a 0573 wich is the Brake Pedal sensor - who fing cares its bin there for ever. so they go $xxx.xx to fix that I am like why that has noting to do with my MPG Thoughts ? it seems like these guys are a little brain dead . if it cost more then $1000.00 to fix there keeping the car I will go through and take the headlights and wheels off they can have the rest of that POS car . So any idea why my MPG is that of a Hummer ? Link to comment Share on other sites More sharing options...
ACES70 Posted August 2, 2007 Report Share Posted August 2, 2007 ETM should be covered under warranty, you shouldnt have paid a dime. Link to comment Share on other sites More sharing options...
Chilled man Posted August 2, 2007 Author Report Share Posted August 2, 2007 ETM should be covered under warranty, you shouldnt have paid a dime.Flood Damaged Vehicale so no ;) Link to comment Share on other sites More sharing options...
ACES70 Posted August 2, 2007 Report Share Posted August 2, 2007 Flood Damaged Vehicale so no ouch.....good luck Link to comment Share on other sites More sharing options...
Chilled man Posted August 2, 2007 Author Report Share Posted August 2, 2007 P0573 Cruise Control/Brake Switch A Circuit High that is what the code is , it was there before ( i think ) what does this have to do with MPG ? Link to comment Share on other sites More sharing options...
Chilled man Posted August 2, 2007 Author Report Share Posted August 2, 2007 so having switch out the bad sensor for $175.00 isnt much cheaper for me to do and I dont have the time right now <_< Link to comment Share on other sites More sharing options...
Dmsee Posted August 2, 2007 Report Share Posted August 2, 2007 That mpg blowsStage 0 done? Link to comment Share on other sites More sharing options...
Chilled man Posted August 2, 2007 Author Report Share Posted August 2, 2007 That mpg blowsStage 0 done?Car only has 58,000 on it so have even thought of stage 0 and on a NA there will ignition coils there realy isnt a stage 0 persay as on the 850 Link to comment Share on other sites More sharing options...
Dmsee Posted August 2, 2007 Report Share Posted August 2, 2007 yea, did your ETM codes ever came back? Link to comment Share on other sites More sharing options...
Chilled man Posted August 2, 2007 Author Report Share Posted August 2, 2007 yea, did your ETM codes ever came back?nope that was fixed when they changed out the ETM the light is still on but that is from the 0573 code Link to comment Share on other sites More sharing options...
Dmsee Posted August 2, 2007 Report Share Posted August 2, 2007 Try to change that but I dont see how that would affect mpg.Dealer saying that everything is normal? Link to comment Share on other sites More sharing options...
Chilled man Posted August 2, 2007 Author Report Share Posted August 2, 2007 Try to change that but I dont see how that would affect mpg.Dealer saying that everything is normal?yup <_< Link to comment Share on other sites More sharing options...
Dmsee Posted August 2, 2007 Report Share Posted August 2, 2007 Tried different dealership? Link to comment Share on other sites More sharing options...
Chilled man Posted August 3, 2007 Author Report Share Posted August 3, 2007 Tried different dealership? I will once I get that part fixed tommarrow, worst part the closets two are both owned by Lehman, I was thinking going to the west shore location , but who knows maybe this repair will fix it will find out more this weekend when I get the car back and drive it 50 miles and either it takes only 2 gallons or 5 gallons of gas :) Link to comment Share on other sites More sharing options...
starfish Posted August 3, 2007 Report Share Posted August 3, 2007 8-9 mpg has got to be brutal with today's gas prices.Although the OBDII compliant fuel management systems are aggressively looking for faults it is not a one stop shop for all malodies.Have you or has the technician physically looked at the entire fuel system for leaks?Are the brake pads rusted to the caliper mounting guides and not retracting when the pedal is not being applied?Is the parking brake dragging?Is the transmission shifting properly?ETM's flow air and not fuel so I doubt that is your source of trouble. Link to comment Share on other sites More sharing options...
