USSEnterprise Posted August 12, 2007 Report Share Posted August 12, 2007 My car is still overboosting after replacing vacuum lines. I removed the heat shield on the back of the engine, and the wastegate seems very sticky. Its hard to move manually, tending to stick in certain places. I sprayed some WD40, which helped, but quickly burned off. What is a more permanent fix to this? Will I have to disassemble the turbo? Link to comment Share on other sites More sharing options...
dick Posted August 12, 2007 Report Share Posted August 12, 2007 My car is still overboosting after replacing vacuum lines. I removed the heat shield on the back of the engine, and the wastegate seems very sticky. Its hard to move manually, tending to stick in certain places. I sprayed some WD40, which helped, but quickly burned off. What is a more permanent fix to this? Will I have to disassemble the turbo?Wastegate actuator rod free and not rubbing on anything? Does the wastegate move freely when the rod is not attatched? I had a little problem in these areas in the past. Check these areas first. Link to comment Share on other sites More sharing options...
USSEnterprise Posted August 12, 2007 Author Report Share Posted August 12, 2007 Wastegate actuator rod free and not rubbing on anything? Does the wastegate move freely when the rod is not attatched? I had a little problem in these areas in the past. Check these areas first.The rod is not rubbing on anything, and the wastegate does not more any more freely with the rod detached.Thanks Link to comment Share on other sites More sharing options...
USSEnterprise Posted August 14, 2007 Author Report Share Posted August 14, 2007 The rod is not rubbing on anything, and the wastegate does not more any more freely with the rod detached.ThanksIs there a bearing or something inside the turbo that either needs to be cleaned or replaced? Link to comment Share on other sites More sharing options...
Mesoam Posted August 14, 2007 Report Share Posted August 14, 2007 take the pin out and take the rod off the actuator see if it moves freely on the actuator side or if its getting hung up on the exhaust housing Link to comment Share on other sites More sharing options...
USSEnterprise Posted August 14, 2007 Author Report Share Posted August 14, 2007 take the pin out and take the rod off the actuator see if it moves freely on the actuator side or if its getting hung up on the exhaust housingIts definitely the little lever on the manifold, the vacuum actuator works fine. When I sprayed WD40 on the lever, it freed it up, but once the WD40 burned off, it got sticky again. Link to comment Share on other sites More sharing options...
