Marzocchi Posted August 15, 2007 Report Share Posted August 15, 2007 Hi,I made my first wot run with the 16G6 at 14 and 16 psi with the large MAF and 46lb injectors. During the run, it was always around 10.4. I've spoke with local tuners and one of them told me it was rich and safe but the other tuner told me it was way too rich and would wash my cylinders very fast.I plan to adjust the fuel a little with the air fuel controller but I would like to know with these engines with stock rods, what ratio should I tune for medium throttle low boost and high boost and wot?Is 10 psi under 4000 rpm too much?So far, the 16G6 with the 7cm^2 housing spools almost as fast as the stock turbo, but I've never felt my head move that hard into the headrest. Link to comment Share on other sites More sharing options...
JCviggen Posted August 15, 2007 Report Share Posted August 15, 2007 At 4000rpm you can safely do 18-20psi if its a half descent tune. 10.4 is very rich but not exactly washing the walls rich on the short term. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 15, 2007 Report Share Posted August 15, 2007 I'd say shoot for 11.9 - 12.5. Keep an eye on your EGTs. Link to comment Share on other sites More sharing options...
TorqueSteer Posted August 15, 2007 Report Share Posted August 15, 2007 I run 18 psi on my Super16g, even with water injection, I keep it around 11.6 to 11.8, although I must say that when I had it at 12.5, I felt a significant power gain, but didnt want to risk anything running that afr in the 100 degree weather down here. Link to comment Share on other sites More sharing options...
Denovae Posted August 15, 2007 Report Share Posted August 15, 2007 I like to stay 11-11.5 ish. It's mostly personal preference. My EGTs run high so I added some fuel to drop EGTs slightly. All tuners do it differently. Link to comment Share on other sites More sharing options...
Marzocchi Posted August 16, 2007 Author Report Share Posted August 16, 2007 Thanks for the information.This is on the stock ECU with just bigger injectors and MAF housing.I will borrow an SAFC from my friend and try to make some changes. Would it be safe to run 18 psi with stock timing? Weather here is very cool averaging 15°C.Pierre Link to comment Share on other sites More sharing options...
'93 Dave Posted August 16, 2007 Report Share Posted August 16, 2007 thats freezing Link to comment Share on other sites More sharing options...
VolvoKid4Life Posted August 16, 2007 Report Share Posted August 16, 2007 15 C isnt too bad... only like 59 F, i wouldnt mind takin my car on the dyno at that temp ... if my car ran right now....JR Link to comment Share on other sites More sharing options...
TorqueSteer Posted August 16, 2007 Report Share Posted August 16, 2007 Im not sure how different your turbo is than mine, but on mine, I ran 18 psi on stock timing for awhile, but I then retarted the timing, 5 extra degrees by 18psi, and noticed a large gain in power.Thanks for the information.This is on the stock ECU with just bigger injectors and MAF housing.I will borrow an SAFC from my friend and try to make some changes. Would it be safe to run 18 psi with stock timing? Weather here is very cool averaging 15°C.Pierre Link to comment Share on other sites More sharing options...
Denovae Posted August 16, 2007 Report Share Posted August 16, 2007 Im not sure how different your turbo is than mine, but on mine, I ran 18 psi on stock timing for awhile, but I then retarted the timing, 5 extra degrees by 18psi, and noticed a large gain in power.you pulled timing and gained power? :huh: Link to comment Share on other sites More sharing options...
Marzocchi Posted August 16, 2007 Author Report Share Posted August 16, 2007 Im not sure how different your turbo is than mine, but on mine, I ran 18 psi on stock timing for awhile, but I then retarted the timing, 5 extra degrees by 18psi, and noticed a large gain in power.Is this with or without water injection?I have the knocksense installed and the light is blinking some times so I am wondering if it is normal? Sometimes around ~3500 rpm and a little above 5k.I will install a safc and egt gauge this week end and see what I can do.Thanks,Pierre Link to comment Share on other sites More sharing options...
TorqueSteer Posted August 17, 2007 Report Share Posted August 17, 2007 Yes, if when using the stock timing maps, there was knock and the stock ecu was retarding timing even further to almost a "safe" mode, this kills power. By retarding timing in proper amounts, (I did one degree for every additional pound of boost above 12 psi), this prevents the knock, and thus the ecu from freaking out and pulling large amounts of timing.you pulled timing and gained power? Link to comment Share on other sites More sharing options...
TorqueSteer Posted August 17, 2007 Report Share Posted August 17, 2007 Is this with or without water injection?I have the knocksense installed and the light is blinking some times so I am wondering if it is normal? Sometimes around ~3500 rpm and a little above 5k.I will install a safc and egt gauge this week end and see what I can do.Thanks,PierreThis is with water injection. The knock light that I have, will blink only whenever the knock sensors pick up a vibration, this dosent necessarily mean its knock from detonation, sometimes its exhaust sound, heat shield rattle etc...The ecu does pay attention to even these brief moments of knock, although it wont pull timing or add fuel unless it notices a pattern of repeated knock. Link to comment Share on other sites More sharing options...
turbor850 Posted August 17, 2007 Report Share Posted August 17, 2007 Yes, if when using the stock timing maps, there was knock and the stock ecu was retarding timing even further to almost a "safe" mode, this kills power. By retarding timing in proper amounts, (I did one degree for every additional pound of boost above 12 psi), this prevents the knock, and thus the ecu from freaking out and pulling large amounts of timing.have you dynoed that car yet ? i'm interested in those numbers Link to comment Share on other sites More sharing options...
TorqueSteer Posted August 17, 2007 Report Share Posted August 17, 2007 I dyned it before I realised the problem with the timing, the car was shooting black smoke out of the turbo/downpipe joint from running so rich, wasn't a fun time, numbers are not worth sharing lol.have you dynoed that car yet ? i'm interested in those numbers Link to comment Share on other sites More sharing options...
