nagrod18 Posted August 24, 2004 Report Share Posted August 24, 2004 I plugged the leads of some little LED sized lamps into the speaker terminals of my sub and they are pretty cool. It is a cheap and easy way to have some lights that go with the bass and I have a switch wired in so that whenever I don't want them, they're off. I'm not sure what any negatives might be though, I can't tell any difference in sound, but let me know if you can think of a negative. Link to comment Share on other sites More sharing options...
Veneficus Posted August 24, 2004 Report Share Posted August 24, 2004 I might have to play with this idea tomorrow. Link to comment Share on other sites More sharing options...
Chris_R Posted August 24, 2004 Report Share Posted August 24, 2004 You may be affecting the impedance load that your amp is seeing. If you have a decent quality amp, and aren't running too many speakers with it, then this shouldn't be a problem. -Chris Link to comment Share on other sites More sharing options...
Bing_0 Posted August 24, 2004 Report Share Posted August 24, 2004 the only issues i may see is as chris said, impedance issue, also, sometimes it could cuase a ground loop and induced noise but you seem to be fine... the only time i did something similiar i went and got a cheapo kraco amp from walmart, hooked it up, and hten use this thing to exclusiveply power some led bars...worked out okay (it wasnt my idea), so... i think you should be fine b Link to comment Share on other sites More sharing options...
Veneficus Posted August 24, 2004 Report Share Posted August 24, 2004 Tried it, didn't like it. To each his own. Link to comment Share on other sites More sharing options...
