FastWagon95 Posted September 11, 2007 Report Share Posted September 11, 2007 Just got the BOV on..currently with just a capped off CBV, I have a blanking plate to install tomorrow. I noticed a loss in boost with the BOV and it doesn't feel as torquey or quick..It's a real Greddy type RSIs the lack of blanking plate causing this?Thanks, Taylor Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted September 11, 2007 Report Share Posted September 11, 2007 Loss of boost sounds like the BOV is leaking. Is it a real Greddy RS or a knockoff? Adjust the tension on it?The blanking plate can help you recover boost that is leaking out at the CBV, but if it was not leaking out before the BOV install then that would be irrelevant. Regardless, the blanking plate is mandatory (in my opinion) to install when a BOV is put on. Link to comment Share on other sites More sharing options...
FastWagon95 Posted September 11, 2007 Author Report Share Posted September 11, 2007 Loss of boost sounds like the BOV is leaking. Is it a real Greddy RS or a knockoff? Adjust the tension on it?It is real, should I tighten the adjusment screw or loosen it? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted September 11, 2007 Report Share Posted September 11, 2007 Personally I'd say tighten it. Link to comment Share on other sites More sharing options...
EricF Posted September 11, 2007 Report Share Posted September 11, 2007 You say you just capped off the CBV (like capped off the vacuum tee)? This is no good... You will want to leave it hooked up until you have a blockoff plate installed. Link to comment Share on other sites More sharing options...
FastWagon95 Posted September 11, 2007 Author Report Share Posted September 11, 2007 You say you just capped off the CBV (like capped off the vacuum tee)? This is no good... You will want to leave it hooked up until you have a blockoff plate installed.Well its staying like that till after school tomorrow..but I did tighten it down some Link to comment Share on other sites More sharing options...
Denovae Posted September 12, 2007 Report Share Posted September 12, 2007 your CBV is leaking. without boost being routed to the diaphragm, the spring is not strong enough by itself to hold boost from the turbo in the system. CBV springs are weak - think 2-4lb/in, so when your TB closes the pressure on the CBV side is less than that on the turboside which causes the CBV to open. as you have it there is no pressure to it so as much boost is escaping through there as possible and with your wastegate closed the turbo is actually worked harder to maintain boost.Think of your CBV as power assisted steering, without the power assist it can not work properly or to it's fullest potential.get that BOP - block off plate, black silicon the outline, screw it on and you should be fine. don't mess with BOV - it's not the culprit ( unless you have a truly shitty BOV ). Link to comment Share on other sites More sharing options...
FastWagon95 Posted September 12, 2007 Author Report Share Posted September 12, 2007 your CBV is leaking. without boost being routed to the diaphragm, the spring is not strong enough by itself to hold boost from the turbo in the system. CBV springs are weak - think 2-4lb/in, so when your TB closes the pressure on the CBV side is less than that on the turboside which causes the CBV to open. as you have it there is no pressure to it so as much boost is escaping through there as possible and with your wastegate closed the turbo is actually worked harder to maintain boost.Think of your CBV as power assisted steering, without the power assist it can not work properly or to it's fullest potential.get that BOP - block off plate, black silicon the outline, screw it on and you should be fine. don't mess with BOV - it's not the culprit ( unless you have a truly shitty BOV ).Okay, that makes sense, I'll get the block off plate on tomorrow after school. I should be safe driving it until then right? Link to comment Share on other sites More sharing options...
Denovae Posted September 12, 2007 Report Share Posted September 12, 2007 Okay, that makes sense, I'll get the block off plate on tomorrow after school. I should be safe driving it until then right?yea just don't be too hard on it. the turbo will be spinning faster to provide the same amount of boost as normal and i'm not sure if it could be spinning too fast and cause damage ( i don't think it will but better safe than sorry ). Link to comment Share on other sites More sharing options...
FastWagon95 Posted September 12, 2007 Author Report Share Posted September 12, 2007 yea just don't be too hard on it. the turbo will be spinning faster to provide the same amount of boost as normal and i'm not sure if it could be spinning too fast and cause damage ( i don't think it will but better safe than sorry )...I'll probably turn the boost down on the MBC, my dumbass turned it up after I lost 5lbs from the BOV :lol: :lol: Link to comment Share on other sites More sharing options...
EricF Posted September 12, 2007 Report Share Posted September 12, 2007 Dude just hook a vacuum line up to it from the manifold like it was before and it will be good to go for as long as it takes for you to have free time to put the blockoff plate on... And you'll still hear the BOV. Link to comment Share on other sites More sharing options...
FastWagon95 Posted September 12, 2007 Author Report Share Posted September 12, 2007 Dude just hook a vacuum line up to it from the manifold like it was before and it will be good to go for as long as it takes for you to have free time to put the blockoff plate on... And you'll still hear the BOV.I just did that..spliced the vaccum line going to the BOV back into the CBV as well with a T-fitting..it was the only t-fitting i had at the moment so i had to use it..it's a little big for the vaccum lines so I hope it stays on. Its a turbobricks special with zip-ties and all just test drove it, BOV is quieter but it should be fine.. Link to comment Share on other sites More sharing options...
Denovae Posted September 12, 2007 Report Share Posted September 12, 2007 mmmm zip-ties... a boost addict's best friend. Link to comment Share on other sites More sharing options...
RvolvoR Posted September 12, 2007 Report Share Posted September 12, 2007 I just did that..spliced the vaccum line going to the BOV back into the CBV as well with a T-fitting..it was the only t-fitting i had at the moment so i had to use it..it's a little big for the vaccum lines so I hope it stays on. Its a turbobricks special with zip-ties and all just test drove it, BOV is quieter but it should be fine..i represent that remark Link to comment Share on other sites More sharing options...
rynodyno312 Posted September 12, 2007 Report Share Posted September 12, 2007 mmmm zip-ties... a boost addict's best friend.My I/C piping definitely relies on several strategically placed zip ties to avoid rubbing/sagging. :tup: Link to comment Share on other sites More sharing options...
