I <3 Owned
Zaitz
My passenger side rear door speaker crackles with the bass turned up and when the volume is turned high. Any suggestions on putting something in that is stock size and better then the stock speakers? I turn them up pretty loud. Was just at best buy and I cant decide on any. Stock size and better then stock.
Push your fader forward. Should be at least 70-75 percent forward, anyways. If it still bothers you get some 5.25 Infinity References or something. Kappas are 2 ohm, Reference is 4. You want 4 ohm speakers in the doors. Don't forget to unplug the rear deck ones.
Fader should be pushed towards the back imo, towards the front sounds terrible. I have mine 60-70% towards the back. Anyway I'll probably just get the infinitys. They are better then stock right? Why unplug the rear deck ones? I am not replacing them myself btw.
Well, your opinion is wrong. It sounds better faded rear because it's a bad and barely working setup. Then entire audio community agrees that the fader should be forward.
You won't have the correct ohm load without unplugging the rears.
Even a retarded person could install rear door speakers. Please don't have someone do this for you.
Are you nuts Owned? Faded to the front sounds flat and unbalanced. Bad and barely working? There is one speaker that crackles on high bass, thats it. Why would you fade to the front when the best speakers in the car are the rear deck ones? I dont know of anyone who fades to the front. But you must be right, you are a moderator on VS.
Rear door speakers are 8ohm right? Thats why you disconnect the back rear decks? I can do this then on my 855R right?
Yes and yes. You don't have a rear deck but you do have rear tweets that get unplugged.
I'm not just right because I'm a mod, but because I've done thousands of audio installs and you can't even unscrew the four Torx to replace your speakers. :monkey:
Now I see why no one helped you. :lol:
