stew Posted August 27, 2004 Report Share Posted August 27, 2004 Hi all,After a bit of info and experience.It is time to replace the Heater Blower Motor in the 1995 850T5. Fcp Groton has two that are available for the 850.6820812OE Heater Bower Motor Assy w/ Cage fits all 850 Models $129.00 Behr 6820812 Heater Bower Motor Assy w/o Cage fits all 850 Models $89.00 Bosch.Any ideas on which is actually in the car or which one is a better option for replacement??? Is there a $40.00 difference in quality???CheersStew B) Link to comment Share on other sites More sharing options...
Bay13 Posted August 27, 2004 Report Share Posted August 27, 2004 Get the first one it has the blower cage on the motor and it's balanced to the motor, if you swap the one you have to the motor it might not be balanced or you might get by. Link to comment Share on other sites More sharing options...
kenhoeve Posted August 27, 2004 Report Share Posted August 27, 2004 My contention is that the cage basically balances itself(meaning there are clips already installed from the factory that balance the cage), so there is no need to balance it to the motor. In other words, if you have the means to get the old one off, it is pressed on, go for it. It is a bit of work but can be done. Then swap it onto the new one with a little hammering. Save $40.I did this successfully and saved $40. Booyah. Link to comment Share on other sites More sharing options...
James100 Posted August 28, 2004 Report Share Posted August 28, 2004 Stew, How did you narrow it down to the blower? I have the same problem on a '94 850 turbo with ECC where the blower stopped working but im not sure if its some electrical component before you get to the blower. Ive taken out the glove box and the otherparts below it so Ive gotten a good look at whats in there. Link to comment Share on other sites More sharing options...
Bay13 Posted August 28, 2004 Report Share Posted August 28, 2004 Good point, there is a resistor pack that could also cause the blower to not work. Link to comment Share on other sites More sharing options...
stew Posted August 28, 2004 Author Report Share Posted August 28, 2004 Hi James,In my case the blower is still working however I have a groan noise that eminates from that area when the fan is first turned on. If I turn it off after a while the noise will not be there as the motor has warmed up.I had my car serviced last week and got the mechanic to check it out. The fan was found to have high resistance and he said that the fan needs to be replaced.Hope this helpsCheers Stew Link to comment Share on other sites More sharing options...
