mstager Posted September 21, 2007 Report Share Posted September 21, 2007 97 850R and the oil cooler line that connects to the oil cooler is leaking at the fitting, anyone know how to replace or fix? is there a special tool used to take apart. Im loosing alot of oil through this fitting Link to comment Share on other sites More sharing options...
850turbo Posted September 21, 2007 Report Share Posted September 21, 2007 97 850R and the oil cooler line that connects to the oil cooler is leaking at the fitting, anyone know how to replace or fix? is there a special tool used to take apart. Im loosing alot of oil through this fittingNope, all you need is some flat heads to get the connector off, and a torx to get the line off from the block. Just put new ones in last week in my 850. Link to comment Share on other sites More sharing options...
Oreo931 Posted September 21, 2007 Report Share Posted September 21, 2007 Nope, all you need is some flat heads to get the connector off, and a torx to get the line off from the block. Just put new ones in last week in my 850.It could just be the O-ring gaskets and not the line if it is leaking at the connection. That will be a lot cheaper than replacing the line. They are around $90 for each of the two lines, so it makes more sense to buy a $2 o-ring and $6 c clamp from volvo before replacing the actual line. Link to comment Share on other sites More sharing options...
