MeanGreenSwedeMachine Posted September 24, 2007 Report Share Posted September 24, 2007 So I changed my PCV hoses and just got the car started today. I have pretty weak vacuum, the engine sounds like its surging in idle, though RPMs stay pretty constant. Exhaust also smells a little funny. I let it idle for a few minutes and it didn't throw any codes. Any ideas?Thanks Link to comment Share on other sites More sharing options...
Guest 850T-5 Posted September 24, 2007 Report Share Posted September 24, 2007 if this just happened and wasn't a problem before, I'd definately retrace your steps and check everything . . . .Any vacuum lines left unhooked during the service, any hoses damaged?Are the hoses all attached properly and clamped securely?Did you replace the Intake Manifold Gasket? Link to comment Share on other sites More sharing options...
MrWinkey Posted September 24, 2007 Report Share Posted September 24, 2007 if this just happened and wasn't a problem before, I'd definately retrace your steps and check everything . . . .Any vacuum lines left unhooked during the service, any hoses damaged?Are the hoses all attached properly and clamped securely?Did you replace the Intake Manifold Gasket?Agreed ...re-trace your work Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted September 24, 2007 Author Report Share Posted September 24, 2007 Yeah, thats the plan for tomorrow, I was just hoping maybe the symptoms would help someone give me better direction than tearing it all apart again. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted September 25, 2007 Report Share Posted September 25, 2007 Yeah, thats the plan for tomorrow, I was just hoping maybe the symptoms would help someone give me better direction than tearing it all apart again.You didnt follow the directions pinned here did you? The ones from Josh? Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted September 25, 2007 Author Report Share Posted September 25, 2007 I did use the ones from Josh, and also these ones that were more detailed: http://www.volvoforums.org.uk/showthread.p...highlight=boostI'm guessing that I probably just didn't get one of the vacuum hoses on tight enough.You didnt follow the directions pinned here did you? The ones from Josh? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted September 25, 2007 Report Share Posted September 25, 2007 The ones from Josh are incorrect. Not sure about the other site. Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted September 25, 2007 Author Report Share Posted September 25, 2007 Do you know off hand what was incorrect about Josh's? I kind of used both depending on which one had better pictures of the step I was on. Link to comment Share on other sites More sharing options...
7 VII 7 Posted September 25, 2007 Report Share Posted September 25, 2007 I believe Josh had bad vacuum hoses identification? Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted September 25, 2007 Author Report Share Posted September 25, 2007 Haha, great. Thats probably exactly where my problem is. Bad vacuum, rough idle, sounds like messed up vacuum hoses. Link to comment Share on other sites More sharing options...
MrWinkey Posted September 25, 2007 Report Share Posted September 25, 2007 I don't know who Josh is but I remember seeing a post with a diagram that the 2 hoses were reversed on the oil trap ...and actually FCP Groton's page had it incorret. Either way I honestly doubt that is your issue. I'm more inclined to think you have a large vac. leak or possibly missed something as stated. If Josh's description is incorrect why hasn't it been pulled where ever it is here? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted September 26, 2007 Report Share Posted September 26, 2007 I don't know who Josh is but I remember seeing a post with a diagram that the 2 hoses were reversed on the oil trap ...and actually FCP Groton's page had it incorret. Either way I honestly doubt that is your issue. I'm more inclined to think you have a large vac. leak or possibly missed something as stated. If Josh's description is incorrect why hasn't it been pulled where ever it is here?That was Josh's. I am not sure who pinned it but I unpinned it Link to comment Share on other sites More sharing options...
7 VII 7 Posted September 26, 2007 Report Share Posted September 26, 2007 just search PCV* in the search and you will get TONS of resources Link to comment Share on other sites More sharing options...
