caanglin Posted February 12, 2013 Report Share Posted February 12, 2013 http://www.youtube.com/watch?v=rUycyqax2kA 1 1 Quote Link to comment Share on other sites More sharing options...
Zappo Posted February 12, 2013 Report Share Posted February 12, 2013 Spiders take over a town in Brazil. Birds must not be hungry. They wouldn't survive long around here because the birds would have eaten all of them. Quote Link to comment Share on other sites More sharing options...
andyb5 Posted February 12, 2013 Report Share Posted February 12, 2013 Matt, your member title and avatar crack me up every time I see them! Quote Link to comment Share on other sites More sharing options...
matt b Posted February 13, 2013 Report Share Posted February 13, 2013 Matt, your member title and avatar crack me up every time I see them! Mine ? I'm thinking about changing the avatar. I just lack ideas. Quote Link to comment Share on other sites More sharing options...
vmzoller Posted February 13, 2013 Report Share Posted February 13, 2013 Yeah I know, I hate light shades of green too, like flash green. Flash green is hot. I LOVE Flash Green Metallic, and that's not even a shade of green it's a shade of aqua/teal/light blue. Quote Link to comment Share on other sites More sharing options...
pdlarson Posted February 13, 2013 Report Share Posted February 13, 2013 YEAH WELL I DON'T LIKE BLUE! SO HA!... I lied, I actually really like blue. We need more green Volvos! (NOT) But a funny story anyway... Some Volvo executives were walking a lot and noticing how many green Volvos were sitting there collecting dust. They asked the local manager why there were so many green Volvos. The manager replied that the green Volvos just weren’t selling very well, so they had excess inventory piling up. The executives suggested a promotion to get rid of the green Volvos and clear up the inventory. The local manager put together a promotion and, sure enough, they started to sell the green Volvos. The production folks noticed this, and promptly started to manufacture more green Volvos to support the growing demand. 1 Quote Link to comment Share on other sites More sharing options...
bdimag Posted February 13, 2013 Report Share Posted February 13, 2013 5 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted February 13, 2013 Report Share Posted February 13, 2013 Stupid question. How do I wire in an indicator light to tell me when the wmi pump turns on? I want to install a light into a blank switch spot to turn on when the pump is on. Quote Link to comment Share on other sites More sharing options...
gmsgltr Posted February 13, 2013 Report Share Posted February 13, 2013 ahhh good idear my aem kit came with a lead from the controller with an indicator light i put it on my dual stage mbc switch i know that doesnt help you ^^^ what kit did you get? or are you piecing a kit together? the pump is always on as you bring fused 12v to it. not sure how they "know" when its cycling Quote Link to comment Share on other sites More sharing options...
caanglin Posted February 13, 2013 Report Share Posted February 13, 2013 Couldn't you just buy a cheap two wire light, ground to the water kit ground and tap in to a positive off the pump also? Quote Link to comment Share on other sites More sharing options...
gilber33 Posted February 13, 2013 Report Share Posted February 13, 2013 ahhh good idear my aem kit came with a lead from the controller with an indicator light i put it on my dual stage mbc switch that doesnt help you ^^^ what kit did you get? or are you piecing a kit together? the pump is always on as you bring fused 12v to it No it's not. It's a switched 12V source to the boost control solenoid, and when I reach the desired boost pressure set by the solenoid it turns the pump on. I have the Stage 1 trunk mount CoolingMist kit. I want an indicator light for when the system has power, i.e. before the boost control solenoid, and then after the solenoid for when the pump is on. All the indicator lights I see have two prongs on the back, I'm assuming a power and ground. I just need to know if these are just wired in parallel with what I want the light for or what. The wiring for my kit is very simple: Couldn't you just buy a cheap two wire light, ground to the water kit ground and tap in to a positive off the pump also? That's all I want. Just to put in a blank switch cover. Is that all it is? Splice the power lead off of the water pump power lead and then ground the light out (it doesn't have to share the same ground as the water pump, does it?) I was just going to ground the water pump out in the trunk. Quote Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 13, 2013 Report Share Posted February 13, 2013 Can't you tap either the ground on the pump, or the output on the relay (red wire) because neither are powered unless the relay activates? Quote Link to comment Share on other sites More sharing options...
gilber33 Posted February 13, 2013 Report Share Posted February 13, 2013 Well, I don't want to tap the ground at the pump because it will be in the trunk and I'm just going to ground it out back there with a sheet metal screw. I want one light before the boost solenoid to tell me the system has power one light after the boost solenoid to tell me the pump is running one light for the level sensor in the tank to obviously tell me when it's low For the two indicator lights for the pump I am assuming I just need to tap the power lead before the boost solenoid and ground out the light and then tap the power lead after the boost solenoid and ground out the light. Is that all it is? Is it this elementary: I feel like it shouldn't even be a discussion. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted February 14, 2013 Report Share Posted February 14, 2013 What I'm learning in statistics class tonight 1 Quote Link to comment Share on other sites More sharing options...
Brady Posted February 14, 2013 Report Share Posted February 14, 2013 What I'm learning in statistics class tonight Teacher is either oblivious or hilarious Quote Link to comment Share on other sites More sharing options...
