MeanGreenSwedeMachine Posted September 28, 2007 Report Share Posted September 28, 2007 So I'm working on upgrading my sound system, I already replaced the front doors with Infinity References and plan on buy tweeters for the dash. For the rear though, I know that most recommend disconnecting the rear door speakers and upgrading the rear deck. Would this be worth it in the wagon since the speakers are much further back? And would something like this fit in the rear wagon speakers? http://www.crutchfield.com/S-5j5IEff61gX/A...AV05&tp=919Thanks Link to comment Share on other sites More sharing options...
Owned Posted September 28, 2007 Report Share Posted September 28, 2007 So I'm working on upgrading my sound system, I already replaced the front doors with Infinity References and plan on buy tweeters for the dash. For the rear though, I know that most recommend disconnecting the rear door speakers and upgrading the rear deck. Would this be worth it in the wagon since the speakers are much further back? And would something like this fit in the rear wagon speakers? http://www.crutchfield.com/S-5j5IEff61gX/A...AV05&tp=919ThanksYou don't need more tweets on the dash, there are tweets on the Refs. You will mess with the impedance by doing that, also. For a wagon I would disconnect the rear pillar speakers and upgrade the doors with another set of Refs or something similar. If you can find something without tweets, that would be best. Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted October 3, 2007 Author Report Share Posted October 3, 2007 Thanks, I'll do that. Should I disconnect the dash tweeters as well, or no?Thanks again. Link to comment Share on other sites More sharing options...
Owned Posted October 3, 2007 Report Share Posted October 3, 2007 Thanks, I'll do that. Should I disconnect the dash tweeters as well, or no?Thanks again.If you have the Refs in the front doors you shouldn't have the stock dash tweets connected. The factory speakers are wired in parallel and are 8 ohm. Refs are 4 ohm. If you put another set of Refs in the dash you'd be running the HU at 2 ohms which would be pushing it too hard. It would work, but it's not good for the HU (excess heat/shortened life) and it's just incorrect. Link to comment Share on other sites More sharing options...
MeanGreenSwedeMachine Posted October 3, 2007 Author Report Share Posted October 3, 2007 Ok, so disconnect dash and rear speakers. I'll probably buy another set of references for the rear doors, because I can't find anything 5 1/4 without tweeters.Thanks. Link to comment Share on other sites More sharing options...
