Guest Guest_Mike_* Posted October 7, 2007 Report Share Posted October 7, 2007 Does anyone know the purpose of the thin black cable on air filter cover? Mine is broken (1999 S70). Link to comment Share on other sites More sharing options...
Dmsee Posted October 7, 2007 Report Share Posted October 7, 2007 Vacuum maybe ?is it a electronic cable or hose? Link to comment Share on other sites More sharing options...
Guest Guest_Mike_* Posted October 7, 2007 Report Share Posted October 7, 2007 It's just a very thin black plastic cord (tube like) that attaches to the back side of the air filter cover. it's much thinner than a pencil. it appears to have a very small hole in the center of the cable, so maybe it measures vacuum pressure or something. what strikes me as odd is how flimsy it is...it almost looks like it's just meant as a tether to hold the air filter cover in place when you take it off. i tried to follow the cord as it was routed below the air filter, but I could not easily see where the other end of the cord is attached. i didn't see any electronics within the cord. does this additional information help??? :huh: Link to comment Share on other sites More sharing options...
Dmsee Posted October 7, 2007 Report Share Posted October 7, 2007 Its probably a vacuum hose look closely at the airbox Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 7, 2007 Report Share Posted October 7, 2007 it's a vac line Link to comment Share on other sites More sharing options...
Guest Guest_Mike_* Posted October 8, 2007 Report Share Posted October 8, 2007 Agreed. so it's a vacuum line.Does anyone know what this little vacumm line does? Since it's broke at the 90 degree elbow going into the airbox, it's obviously not pulling any vauum in my car. At yet I have not experienced any problems. I've read on other forums many people saying that these elbows do tend to brake easily, but no one has been able to tell me what this silly little vacuum lines DOES? :huh: Link to comment Share on other sites More sharing options...
Dmsee Posted October 8, 2007 Report Share Posted October 8, 2007 I assume you have NAI am not really sure if S70 has that but its worth a shot. Well, there is a thing called thermostat which closes or opens. When your car is cold it will let the warm air from exhaust to heat it up fasterJust put it back on it. the reason u not having any problems because its not an important part. I had this thing disconnected on 850 and it worked fine Link to comment Share on other sites More sharing options...
Guest Guest_Mike_* Posted October 8, 2007 Report Share Posted October 8, 2007 Thanks.I'm sorry, but I don't know what is meant by "NA" in this context.(?)I'm not exactly sure how I'll put it back on since the connecting elbow is the part that is cracked. Maybe I can buy a new elbow, or maybe I can just feed the hose directly into the air filter compartment without the elbow. Not sure how I would do that though... Link to comment Share on other sites More sharing options...
