flippu10 Posted October 20, 2007 Report Share Posted October 20, 2007 I'm trying to replace the ball joints. I've removed the nut where it attaches to the control arm. I've also removed the control arm from the ball joint. However, I can't detach it from the hub. The new ball joint looks like it's got a circular ball that has a serrated edge that fits into a hole in the hub. Is there a special tool or technique to pop it loose.Any help is much appreciated. Link to comment Share on other sites More sharing options...
flippu10 Posted October 20, 2007 Author Report Share Posted October 20, 2007 I'm trying to replace the ball joints. I've removed the nut where it attaches to the control arm. I've also removed the control arm from the ball joint. However, I can't detach it from the hub. The new ball joint looks like it's got a circular ball that has a serrated edge that fits into a hole in the hub. Is there a special tool or technique to pop it loose.Any help is much appreciated.Never mind. I figured it out. I used a metal putty knife first between the ball joint and the hub to get a separation. Then I gradually separated them apart by using a flat head screw driver, increasing the thickness using larger ones. I used 2 screwdrivers on either end to maintain a balanced separation until it popped out. No prob. Now I can put the new one on. Link to comment Share on other sites More sharing options...
