blazen244 Posted October 27, 2007 Report Share Posted October 27, 2007 The boost gauge in the dash just stopped working but I can still hear the urbo spooling and I don't see a difference in the performance also another thing is this hose the comes off the turbo it has somewhat of a weird plastic bend in it is there anyway to change this part or have anybody had an issue with this part Link to comment Share on other sites More sharing options...
Oreo931 Posted October 27, 2007 Report Share Posted October 27, 2007 The boost gauge in the dash just stopped working but I can still hear the urbo spooling and I don't see a difference in the performance also another thing is this hose the comes off the turbo it has somewhat of a weird plastic bend in it is there anyway to change this part or have anybody had an issue with this partIt is possible that the hose came off of the back at the back of the dash. You will have to remove the gauge cluster (easy to do) and check the connection in the back. You could also undo the kick panel under the steering wheel and check the vac lines there to see if anything is disconnected.I dont know what hose you are talking about that has a weird plastic bend...I need pictures or a better description. Link to comment Share on other sites More sharing options...
blazen244 Posted October 27, 2007 Author Report Share Posted October 27, 2007 It is possible that the hose came off of the back at the back of the dash. You will have to remove the gauge cluster (easy to do) and check the connection in the back. You could also undo the kick panel under the steering wheel and check the vac lines there to see if anything is disconnected.I dont know what hose you are talking about that has a weird plastic bend...I need pictures or a better description.I found a picture of the tube I'm talking aboutthis is the link to it part number 10 is the ripped hose I need to know what this is and what it do if you can help me with that I know now where to get it from http://www.fcpgroton.com/images/pcv9596_850T.jpg Link to comment Share on other sites More sharing options...
Dmsee Posted October 28, 2007 Report Share Posted October 28, 2007 Are you still on OEM hoses? Time to change. Link to comment Share on other sites More sharing options...
Volvoteen Posted October 28, 2007 Report Share Posted October 28, 2007 No biggie...this happened to me in my old 854T all the time...check the lines under the dash like Oreo said...and look under the hood too. Sometimes the heat just makes the lines a little "crispy" so they come apart pretty easily Link to comment Share on other sites More sharing options...
blazen244 Posted October 28, 2007 Author Report Share Posted October 28, 2007 <_< Should I replace all the hoses and if so is there a particular vender to ge them from Link to comment Share on other sites More sharing options...
Dmsee Posted October 29, 2007 Report Share Posted October 29, 2007 Yes your OEM rubber lines are eventually will wear out. Stylinmotors.com look for 850 vac kit Link to comment Share on other sites More sharing options...
