roby Posted October 31, 2007 Report Share Posted October 31, 2007 my back left speaker broke.i went to the store and got a speaker and now i am not sure how to wire it.on the original speaker there is no + or - the original speaker has a black and a brown wire and on the default wire there is a kid of a connector it says on 1 (black wire) and 2 on the (brown wire)what do you guys thin which one is the + and the - I have a Volvo 850thanks Link to comment Share on other sites More sharing options...
Dmsee Posted October 31, 2007 Report Share Posted October 31, 2007 I would say black is - because most of the time it is Link to comment Share on other sites More sharing options...
viperman135 Posted October 31, 2007 Report Share Posted October 31, 2007 If you have a test light ground the test light and test both connections. The one that lights up is + and the one that does not is - Link to comment Share on other sites More sharing options...
BEJinFBK Posted October 31, 2007 Report Share Posted October 31, 2007 If you have a test light ground the test light and test both connections. The one that lights up is + and the one that does not is -Yoda sez:A poor grasp of amplifiers you have.Some education you should pursue. Ohhh.Car amps haven't been common ground since cassette decks, dude.And shooting 12 volts up a speaker lead, even with a current limiting light bulbjust is NOT a good plan. If you can't get an indication off of the speaker, you havean easy option before you go lookin' for a wiring diagram.If the old speaker still "works" and just got buzzy, a AA battery can solve this problem.The cone wil go either in or out when you connect it. If it moves out, then the + sideof the battery is connected to the + of the speaker. Just don't leave it hooked up!All you need is a quick speaker pop to find out.If the bad speaker is totally open, ya gotta take it a little further. I'd find a diagram or have someone that knows a little more about stereos take a look. Some folks can detect phase by ear. There are also some test discs out there that will pop the speakers for you in and out of phase and that will give you the answer you seek, Young Jedi. B) Link to comment Share on other sites More sharing options...
