matt b Posted March 9, 2011 Report Share Posted March 9, 2011 $100 is great Adam. As for the horns Gabe: yeah, you won't hear them and neither will the car in front of you. I thought mine had died (that's where they are) but not, they just are too quiet for that spot. Link to comment Share on other sites More sharing options...
gilber33 Posted March 10, 2011 Report Share Posted March 10, 2011 As for the horns Gabe: yeah, you won't hear them and neither will the car in front of you. I thought mine had died (that's where they are) but not, they just are too quiet for that spot. Really? Meh. Maybe I'll just keep in the same spot they are now. You can barely see them anyways. ;) Link to comment Share on other sites More sharing options...
matt b Posted March 10, 2011 Report Share Posted March 10, 2011 Really? Meh. Maybe I'll just keep in the same spot they are now. You can barely see them anyways. I plan on grabbing louder ones when I come across a decent deal. Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 10, 2011 Report Share Posted March 10, 2011 --Installed Nokya H3 2500k-55w fog bubls --Took a look at the throttle cable and what I needed to do before I went forward and replaced it --Inspected a fluid leak (Oil or ATF?) on the subframe of my car. Not sure which it is Link to comment Share on other sites More sharing options...
(n)A-GAME Posted March 10, 2011 Report Share Posted March 10, 2011 Ordered a bunch of parts for it Local dealer made some money on me. New front engine mount bracket. Different than the 98 style. Found that out the hard way. New climate box damper motor clip. Damn thing broke in my hand as I put everything back together following the evap job. Pressure plate-flywheel bolts. Had some, but no idea if they were the right ones and the person I bought the swap kit from didn't label anything. And Volvo manual trans fluid. Too afraid of Redline locking up in the cold. Link to comment Share on other sites More sharing options...
GltGreco Posted March 10, 2011 Report Share Posted March 10, 2011 new hd swaybar endlinks went in feels a little bit better! Had to go justin on one of the bolts and break out the saw haha Link to comment Share on other sites More sharing options...
matt b Posted March 10, 2011 Report Share Posted March 10, 2011 I have run Volvo stuff since the swap in FL (forever ago) and it's fine. Shifting is harder in colder weather (gears aren't as smooth) but for 11 months of the year, it's perfect. Link to comment Share on other sites More sharing options...
Smithwicks Posted March 10, 2011 Report Share Posted March 10, 2011 Popped in my Blitzsafe adapter and routed it through the center console, easy install. And finally got around to replacing my two burned out brake bulbs. Link to comment Share on other sites More sharing options...
Get Some Posted March 11, 2011 Report Share Posted March 11, 2011 FINALLY installed the foglights.. cept i think im missing a relay somewhere.. or a fuse Link to comment Share on other sites More sharing options...
nowhereman Posted March 11, 2011 Report Share Posted March 11, 2011 Swapped out the sc-816 for an alpine cde 103-bt. Removed the dealer badge and the GLT from the trunk Upgraded all the crappy yellow headlight bulbs for hella bulbs. Link to comment Share on other sites More sharing options...
cheapwagon Posted March 11, 2011 Report Share Posted March 11, 2011 --Took a look at the throttle cable and what I needed to do before I went forward and replaced it Figure it out? Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 11, 2011 Report Share Posted March 11, 2011 Figure it out? Yeah I think so.. if I have a new cable and housing... can't I just rip it out.. the white clips come on the new throttle cable. I mean I will try to finesse it out but still. Link to comment Share on other sites More sharing options...
Black Betty Posted March 11, 2011 Report Share Posted March 11, 2011 Yeah I think so.. if I have a new cable and housing... can't I just rip it out.. the white clips come on the new throttle cable. I mean I will try to finesse it out but still. Mine broke when I replaced mine with the manual throttle. IIRC the new one just snaps into the firewall anyways. Link to comment Share on other sites More sharing options...
cheapwagon Posted March 11, 2011 Report Share Posted March 11, 2011 Yeah I think so.. if I have a new cable and housing... can't I just rip it out.. the white clips come on the new throttle cable. I mean I will try to finesse it out but still. Pretty much what I was saying in PM. Have at it. Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 11, 2011 Report Share Posted March 11, 2011 Thanks guys. I am going to do my silicone intercooler lines at the same time since I want to make sure the throttle is correct with the tension on the cable. I am going to stretch those intercooler hoses with my huge hands and use engine oil to shove them on. Link to comment Share on other sites More sharing options...
