850&S80 Posted November 10, 2007 Report Share Posted November 10, 2007 Hi Folks,I have an 1996 850. I guess the panel been pulled so many times to check engine codes, that it just hangs down now, practically hitting my legs as I drive.The screw on the left is entirely missing, it looks like the vinyl is ripped through and there is nothing to put a screw into. The center screw is just attached to vinyl and is just barely hanging on. The last one on the right isn't pretty either.Any advice for a way to put this panel back in place, and keep it there. I guess I need some type of bracket to attach to the lower dash that a screw can be put into to hold the bottom panel.Any suggestions appreciated.Thanks. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted November 10, 2007 Report Share Posted November 10, 2007 1. you don't pull the panel down to check the codes.... obd2 port is under the coin holderPut a plastic clip behind it, and then mount the panel to it then screw into the clip Link to comment Share on other sites More sharing options...
