tp_taylor Posted September 4, 2004 Report Share Posted September 4, 2004 96 855T. Got dash completely out(don't ask) and wanting to change out evap. What seals (part numbers and purchase locations) or other parts are needed for a good rebuild on the ac sys? thanks TT Link to comment Share on other sites More sharing options...
Volvo1 Posted September 4, 2004 Report Share Posted September 4, 2004 The evap P/n is 9171981There is an add on cabin filter kit for this model, 9192522.Only use the OEM Volvo evap. I have seen non-Volvo aftermarket evap's and they did not fit or match up at all.You do not need to drain the coolant at all.Leave the coolant cap on, remove the cooling lines from the firewall.You will loose about 1 cup of coolant. Do not loosen the coolant cap with the cooling lines removed. Bruce------------------------------96 855T. Got dash completely out(don't ask) and wanting to change out evap. What seals (part numbers and purchase locations) or other parts are needed for a good rebuild on the ac sys? thanks TT← Link to comment Share on other sites More sharing options...
850_GLT_owner Posted September 4, 2004 Report Share Posted September 4, 2004 The evap P/n is 9171981There is an add on cabin filter kit for this model, 9192522.Only use the OEM Volvo evap. I have seen non-Volvo aftermarket evap's and they did not fit or match up at all.You do not need to drain the coolant at all.Leave the coolant cap on, remove the cooling lines from the firewall.You will loose about 1 cup of coolant. Do not loosen the coolant cap with the cooling lines removed. Bruce------------------------------←How much does that cost? Link to comment Share on other sites More sharing options...
Bay13 Posted September 4, 2004 Report Share Posted September 4, 2004 There is actually a service kit for the Evaporator replacement.The kit contains:EvapPollen filter and bracketAccumulator"O" ringsNot sure what the cost is for the kit I seem to remember around $450 Try FCPgroton and you should call them, cause they should ask for your year and serial number. Link to comment Share on other sites More sharing options...
tp_taylor Posted September 4, 2004 Author Report Share Posted September 4, 2004 thanks for the help. I have the evap, just need the o rings. Any ideas on part numbers. TT Link to comment Share on other sites More sharing options...
