DouginDenver Posted November 19, 2007 Report Share Posted November 19, 2007 On my 2000 S40, every once in a while - like maybe once every 50 starts - the brake light on the dash is lit at startup, and stays on. Maybe two or three starts later it goes out and stays out for the next 50 starts until the the cycle repeats. Zero other symptoms of any kind. No other codes triggered, no soft or hard pedal, no nothing. What as the most likely cause of such an infrequent thing? Link to comment Share on other sites More sharing options...
Kibim Posted November 19, 2007 Report Share Posted November 19, 2007 It's not particularly cold on these 1 in 50 starts? The light usually indicates pad wear. Checked your pads lately? Link to comment Share on other sites More sharing options...
DouginDenver Posted November 19, 2007 Author Report Share Posted November 19, 2007 It's not particularly cold on these 1 in 50 starts? The light usually indicates pad wear. Checked your pads lately?No, not particularly cold. All temps. Pad wear ? I did not know there was a pad wear sensor except for the old fashioned kind - a scraping noise. Where are these senesors located and how do they work? Link to comment Share on other sites More sharing options...
theForgottenone Posted November 19, 2007 Report Share Posted November 19, 2007 Check the brake fluid resevoir for correct fluid level. If they are then check for the floating device measure the fluid if it get stuck or faulty. Link to comment Share on other sites More sharing options...
MrWinkey Posted November 20, 2007 Report Share Posted November 20, 2007 Check the brake fluid resevoir for correct fluid level. If they are then check for the floating device measure the fluid if it get stuck or faulty.Sounds good to me ;) Link to comment Share on other sites More sharing options...
DouginDenver Posted December 3, 2007 Author Report Share Posted December 3, 2007 Check the brake fluid resevoir for correct fluid level. If they are then check for the floating device measure the fluid if it get stuck or faulty.You were corrrect. The float - which looks kinda like a miniature of the Space Needle in Seattle - is made of some weird porous plastic that actaully becomes saturated with brake fluid and so was no longer very bouyant. Link to comment Share on other sites More sharing options...
theForgottenone Posted December 3, 2007 Report Share Posted December 3, 2007 You were corrrect. The float - which looks kinda like a miniature of the Space Needle in Seattle - is made of some weird porous plastic that actaully becomes saturated with brake fluid and so was no longer very bouyant. Glad you able to solved the problem :P Link to comment Share on other sites More sharing options...
