siever76 Posted November 21, 2007 Report Share Posted November 21, 2007 Got an oil leak coming from in front of the oil pan. Just took it to the shop a couple of weeks and they thought it was coming from around the oil filter. They changed the oil etc... Still got that same oil leak. Going to check it out this week myself is there anything I should look for? Any suggestions would be appreciated Link to comment Share on other sites More sharing options...
MrWinkey Posted November 24, 2007 Report Share Posted November 24, 2007 I have seen them leak at the bottom return hose on the oil trap where it connects too the block. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted November 26, 2007 Report Share Posted November 26, 2007 Dipstick tube o-ring leaking? Oil trap box leaking? Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted November 26, 2007 Report Share Posted November 26, 2007 I have seen them leak at the bottom return hose on the oil trap where it connects too the block.I'd have to agree. Link to comment Share on other sites More sharing options...
YV1LS53 Posted November 26, 2007 Report Share Posted November 26, 2007 Dipstick tube o-ring leaking? Oil trap box leaking?+1 Link to comment Share on other sites More sharing options...
MrWinkey Posted November 28, 2007 Report Share Posted November 28, 2007 +1Hey I haven't had a +1 in awhile but I forgot about the tube o-ring...honestly though it's probably at the trap, most common. Link to comment Share on other sites More sharing options...
YV1LS53 Posted November 28, 2007 Report Share Posted November 28, 2007 I have seen them leak at the bottom return hose on the oil trap where it connects too the block.+2 :D Link to comment Share on other sites More sharing options...
siever76 Posted November 30, 2007 Author Report Share Posted November 30, 2007 Turns out to be the vent box. Going to try to replace it this week. What is the exact term for this part, a vent box, oil trap, etc..Where is a good place to get this part and what other parts need to be replaced when changing the vent box. Any comments will helpThanks Link to comment Share on other sites More sharing options...
YV1LS53 Posted November 30, 2007 Report Share Posted November 30, 2007 Breather Box. I would get OEM ( dealer might be the only place to get them anyway ). You will also have to get the upper & lower box seals. Volvo also has a special tool to remove the left side breather box bolt ( not sure if theres any other way to remove that bolt, if there is someone else will chime in im sure) Link to comment Share on other sites More sharing options...
MrWinkey Posted December 1, 2007 Report Share Posted December 1, 2007 When I do the 80 series I pull the accessories(p/s pump,alternator,and loosen a/c compressor. I feel it's much quicker and easier as the LH bolt for the oil trap is behind the accessory bracket. It's really not as bad as it sounds. Link to comment Share on other sites More sharing options...
siever76 Posted December 1, 2007 Author Report Share Posted December 1, 2007 Do the new oil traps come with the seals and I also plan on replacing the hoses. Is that the only two seals that need replaced.And to Mr.Winkeys reply thanks for the tip Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 1, 2007 Report Share Posted December 1, 2007 When I do the 80 series I pull the accessories(p/s pump,alternator,and loosen a/c compressor. I feel it's much quicker and easier as the LH bolt for the oil trap is behind the accessory bracket. It's really not as bad as it sounds.Blah. Way too much work. Using the special too is so much easier than pulling all of that crap out. Link to comment Share on other sites More sharing options...
siever76 Posted December 2, 2007 Author Report Share Posted December 2, 2007 Blah. Way too much work. Using the special too is so much easier than pulling all of that crap out.? special tool Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 3, 2007 Report Share Posted December 3, 2007 ? special toolI don't know the part # but volvo mad a special tool for doing the oil tap boxes on 6cyl engines. It's a 10mm (maybe 12mm I don't remember) socket welded on to a rod w/ a 3/8" extension. It works well. I wish I had a picture or part #. Link to comment Share on other sites More sharing options...
