blown_volvo850r Posted November 28, 2007 Report Share Posted November 28, 2007 As most of you know, I have the stock Volvo RIP kit, which was recalled. The TB/IAC hose is ripped, and a stock replacement will not work. My plan is to use a silicone 45-degree elbow to replace it, then do a new lower intercooler pipe that has a nipple welded on to run a straight hose to the IAC, which is how the Samco RIP kit works. Problem is, I can't find an aluminum nipple online that will work. Any ideas? The new hose should be here within a week, and I'd like to get the nipple in as well so I can do a new lower intercooler hardpipe and get my new BOV installed. Link to comment Share on other sites More sharing options...
Ã¥tta femtio fem Posted November 28, 2007 Report Share Posted November 28, 2007 im not for sure but i would say that any exhaust shop would be able to fab one up... Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 28, 2007 Report Share Posted November 28, 2007 Samco RIP Kit? Whatcha talkin bout Willis?A 19 or 25mm nipple would probably work fine for the IAC. Link to comment Share on other sites More sharing options...
blown_volvo850r Posted November 28, 2007 Author Report Share Posted November 28, 2007 Couldn't find any aluminum nipples...I think what I'll do is go to Lowe's and get a small aluminum pipe that is the right OD and just have a muffler shop weld a bead around the end of it, then weld it to the new pipe. Already got an aluminum flange for the BOV and the 2.5-2.0" reducer elbow is ordered, so I should be set. The boost leak will finally be fixed...fake HKS is going to my roommate, and the ripped hose is going in the trash can. Link to comment Share on other sites More sharing options...
randomdude Posted November 28, 2007 Report Share Posted November 28, 2007 if you dont use your a/c, just take off your iac, and plug the line& cap the tree. i did and all's well. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted November 28, 2007 Report Share Posted November 28, 2007 Isn't the IAC an IDLE AIR CONTROL? I think it would be bad if it wasn't there Link to comment Share on other sites More sharing options...
blown_volvo850r Posted November 29, 2007 Author Report Share Posted November 29, 2007 Yeah IAC is idle air control...something I take out and clean every 10,000 miles or so. Makes a big difference when it's all clogged up. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted November 29, 2007 Report Share Posted November 29, 2007 Yeah IAC is idle air control...something I take out and clean every 10,000 miles or so. Makes a big difference when it's all clogged up.Yea but completely deleting it would cause codes and the car to run like stuff Link to comment Share on other sites More sharing options...
randomdude Posted November 30, 2007 Report Share Posted November 30, 2007 yes rob, it is the idle air controller, and actually the car runs fine without it. it does throw two codes, but the codes dont affect anything. its purpose is just to up the idle when you turn on the a/c and whatnot. i capped the tree where it hooked up, and pluged the intercooler hose with a huge plug. its completely gone. why would it run like stuff? Link to comment Share on other sites More sharing options...
