jdlc Posted November 29, 2007 Report Share Posted November 29, 2007 For 97 GLT LPT owners, what kind of turbo and housing do you have - is it angled, straight, or conical? Is the turbo 13G?ThanksOrleeC Link to comment Share on other sites More sharing options...
Yellow95 Posted November 29, 2007 Report Share Posted November 29, 2007 13G straight flange.Gary Link to comment Share on other sites More sharing options...
matt b Posted November 29, 2007 Report Share Posted November 29, 2007 13G straight flange.GaryWhat he said. Max output of 15psi, stock tune puts out 8psi. Link to comment Share on other sites More sharing options...
jdlc Posted November 29, 2007 Author Report Share Posted November 29, 2007 QUOTE (matt b @ Nov 29 2007, 02:28 PM) <{POST_SNAPBACK}>What he said. Max output of 15psi, stock tune puts out 8psi.Stock Volvo turbochargers housing are interchangeable right? In other words, if a I have a 16T, I should be able to use the straight flange housing from 97 LPT in place of 15G housing I have now (yes, to avoid confusion, let me state that clearly, I have a 16T that has 15G conical housing in my 94 855 Turbo right now).If affirmative, how hard is this swap? My mechanical accomplishments include t-belt, PCV, pan-drop, pnp-switch, and front-end including axles. (And oh yeah, proper install of t-stat gasket )Thanks,OrleeC Link to comment Share on other sites More sharing options...
matt b Posted November 29, 2007 Report Share Posted November 29, 2007 This is within your abilities, go for it. I'm kicking myself for not having swapped over to a 16T when I had 2 in my possession. Link to comment Share on other sites More sharing options...
ACES70 Posted November 29, 2007 Report Share Posted November 29, 2007 I have a 16T in my possession..... , as well as a 15G, and two 13Ts Link to comment Share on other sites More sharing options...
jdlc Posted November 29, 2007 Author Report Share Posted November 29, 2007 I have a 16T in my possession..... , as well as a 15G, and two 13TsAnd... come on, help me out here man , give some input for my inquiry:"Stock Volvo turbochargers housing are interchangeable right? In other words, if a I have a 16T, I should be able to use the straight flange housing from 97 LPT in place of 15G housing I have now (yes, to avoid confusion, let me state that clearly, I have a 16T that has 15G conical housing in my 94 855 Turbo right now).If affirmative, how hard is this swap? My mechanical accomplishments include t-belt, PCV, pan-drop, pnp-switch, and front-end including axles. (And oh yeah, proper install of t-stat gasket )"BTW, your CBV (got rid of my leaky BOV) did the trick for my leaky boost. And the e-code lenses are installed too w/ SilverStar to my V70, head-lights are now much improved. Thanks a bunch Is your high-flow cat still up for sale?Thanks,OrleeC Link to comment Share on other sites More sharing options...
ACES70 Posted November 29, 2007 Report Share Posted November 29, 2007 And... come on, help me out here man , give some input for my inquiry:"Stock Volvo turbochargers housing are interchangeable right? In other words, if a I have a 16T, I should be able to use the straight flange housing from 97 LPT in place of 15G housing I have now (yes, to avoid confusion, let me state that clearly, I have a 16T that has 15G conical housing in my 94 855 Turbo right now).If affirmative, how hard is this swap? My mechanical accomplishments include t-belt, PCV, pan-drop, pnp-switch, and front-end including axles. (And oh yeah, proper install of t-stat gasket )"BTW, your CBV (got rid of my leaky BOV) did the trick for my leaky boost. And the e-code lenses are installed too w/ SilverStar to my V70, head-lights are now much improved. Thanks a bunch Is your high-flow cat still up for sale?Thanks,OrleeCYes the compressor side of any of the TDo4 turbos are interchangable with any of the exhaust sides. If you have done a T-belt you can do this swap. Glad the parts worked well for you. The cat is pending sale, sorry. You would want to use either the straight or the angled as they are better than the conical in terms of flow. Angled being the best. Link to comment Share on other sites More sharing options...
jdlc Posted November 29, 2007 Author Report Share Posted November 29, 2007 Yes the compressor side of any of the TDo4 turbos are interchangable with any of the exhaust sides. If you have done a T-belt you can do this swap. Glad the parts worked well for you. The cat is pending sale, sorry. You would want to use either the straight or the angled as they are better than the conical in terms of flow. Angled being the best.Words.Thanks a lot guys. Link to comment Share on other sites More sharing options...
