Bracer Posted September 7, 2004 Report Share Posted September 7, 2004 Right guys here's the situation.Ive just replaced my Alpine CDM-9803R With one of these, a Alpine CDA-7893R But now I want to upgrade the stock speaker. At pressent all I have are the ones in the dash, front doors and rear doors with none on the shelf.(P.S. mine is a 850 Saloon)I belive the correct size for the front and rear door to be 5 1/4" so I was looking at these 2 options1) ALPINE SXE-1750S2) ALPINE SXE-1350SI was also thinking of some on the rear shelf but as yet haven't measured what the hole size is but at a guess either 5 1/4" or 6 1/2"So the options are as follows1) ALPINE SXE-1325S2) ALPINE SXE-1725SWhat ones should I get the specs are pretty close and so are the prices.Thanks for the help guys, I appreciate it :) Link to comment Share on other sites More sharing options...
Bing_0 Posted September 7, 2004 Report Share Posted September 7, 2004 if you are running of deck power, then i wouldnt really worry about it, the main limiting factor to your sound system will be the output of hte headunit, instead of hte speakres, just pick which ever one is hte cheaper one b Link to comment Share on other sites More sharing options...
Bracer Posted September 7, 2004 Author Report Share Posted September 7, 2004 if you are running of deck power, then i wouldnt really worry about it, the main limiting factor to your sound system will be the output of hte headunit, instead of hte speakres, just pick which ever one is hte cheaper one b←Quick spec listCD/MP3 Player with RDS Radio4 x 60W High Power OutputMP3 File PlaybackAi-Net CompatibleDetachable Front PanelCD Changer ControlCD Text3 x 4V Preouts for connection of External Amplifiers (FrontRear & Sub)BBEBass Engine PlusRotary ControlVersatile LinkRemote Control ReadyTelephone MuteSwitchable Illumination (Green/Amber)Just installed it, sound brilliant even through the stock speakers. Link to comment Share on other sites More sharing options...
Bracer Posted September 7, 2004 Author Report Share Posted September 7, 2004 Speaker Spec1) ALPINE SXE-1750S5-1/4"(13cm) Component 2-Way Speaker, Peak Power 280W, RMS Power 45W, Frequency Response: 60Hz-20kHz, Sensitivity: 90dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge2) ALPINE SXE-1350S5-1/4"(13cm) Component 2-Way Speaker, Peak Power 250W, RMS Power 40W, Frequency Response: 60Hz-20kHz, Sensitivity: 90dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge 1) ALPINE SXE-1325S5-1/4"(13cm) Coaxial 2-Way Speaker, Peak Power 200W, RMS Power 35W, Frequency Response: 70Hz-20kHz, Sensitivity: 92dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge2) ALPINE SXE-1725S6-1/2"(16.5cm DIN) Coaxial 2-Way Speaker, Peak Power 220W, RMS Power 40W, Frequency Response: 60Hz-20kHz, Sensitivity: 92dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge Link to comment Share on other sites More sharing options...
Bracer Posted September 7, 2004 Author Report Share Posted September 7, 2004 Also am I right on the size for the rear shelf ?As for the price there the same so its the spec / fitment which will decide, will it not matter that one has a full mounting ring and the other has protruding fixing points, dont really want to start cutting things about ;) Link to comment Share on other sites More sharing options...
Bing_0 Posted September 7, 2004 Report Share Posted September 7, 2004 well, if prices are the same, then go with the comp sets, but like i say, your main limiting factor is going to be the amount of clean power hte alpine headunit puts out, rather thant he speakres themselves, i have installed and/or worked with all the components you have listed our 850s fit 5.25s front and rear doors, and 6x9s rear deck, BUT, they dont fit just ANY such sizes, usually one that is not to deep will fit better, so its hard to say if the speakres you listed will work in our cars with out and modifications...b Link to comment Share on other sites More sharing options...
steve s Posted September 11, 2004 Report Share Posted September 11, 2004 even for the same set of speakers, it may fit on one 850 and not another 850 Link to comment Share on other sites More sharing options...
Veneficus Posted September 11, 2004 Report Share Posted September 11, 2004 Just to add to what will fit, larger 6x9s will not fit into the back deck. For example I have some Infinity Kappas that I got that will not fit no matter how hard I try to get them into there. I've heard that you can retrofit the stock black speaker boxes to fit the midline 5x7s into. Link to comment Share on other sites More sharing options...
Guest UnsanePyro Posted September 13, 2004 Report Share Posted September 13, 2004 I have some pioneer speakers, 6x9s, fitted into the black speaker boxes on my 850. They are for sale too :) Link to comment Share on other sites More sharing options...
550 Posted September 13, 2004 Report Share Posted September 13, 2004 How much unsane?? Link to comment Share on other sites More sharing options...
