kwells114 Posted December 8, 2007 Report Share Posted December 8, 2007 Just check the power steering fluid in my 2001 V70, it's low. Manual says ATF. Which ATF. Everything I've read is for the older P1 using Dextron III. What does the P2 use? Thanks for your help. Link to comment Share on other sites More sharing options...
PyROTech Posted December 9, 2007 Report Share Posted December 9, 2007 Just check the power steering fluid in my 2001 V70, it's low. Manual says ATF. Which ATF. Everything I've read is for the older P1 using Dextron III. What does the P2 use? Thanks for your help.if i remember correctly my old p2 car said what to use in the manual. I cant actually tell you what it said, as i dont remember. My benz calls for "Benz dot4+". Which means regular shit with gold flakes. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted December 9, 2007 Report Share Posted December 9, 2007 The manual is wrong. We use the green shit at the dealer. Link to comment Share on other sites More sharing options...
kwells114 Posted December 9, 2007 Author Report Share Posted December 9, 2007 Green stuff?? Can you be more specific? What is in there now is clear to yellow and smells like ATF. ATF from the store smells the same but is red. What gives? Link to comment Share on other sites More sharing options...
ACES70 Posted December 9, 2007 Report Share Posted December 9, 2007 I just use normal power steering fluid. Synthetic stuff made by Penzoil. I think its the higher milage formula. Link to comment Share on other sites More sharing options...
PyROTech Posted December 9, 2007 Report Share Posted December 9, 2007 I just use normal power steering fluid. Synthetic stuff made by Penzoil. I think its the higher milage formula.+1, used the stuff on my other cars. The benz gets special treatment though, dealer serviced so records are 100% perfect for next buyer. Link to comment Share on other sites More sharing options...
Fisher Posted December 10, 2007 Report Share Posted December 10, 2007 Look in your reservoir. If the fluid is reddish, use ATF. If light green or more amber, use CHF-11S. FCPGroton has a good price on it. Personally, I would not pollute the system with anything else. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted December 10, 2007 Report Share Posted December 10, 2007 Look in your reservoir. If the fluid is reddish, use ATF. If light green or more amber, use CHF-11S. FCPGroton has a good price on it. Personally, I would not pollute the system with anything else.Sounds about right. Link to comment Share on other sites More sharing options...
