Olive850 Posted December 9, 2007 Report Share Posted December 9, 2007 hey hows it going, i have a 1995 glt, no mods , non turbo, with about 168K miles on it... i have been getting bad mpgs for the past week, i have recently changed tired but that wouldnt effect it that much, i barely make 230 miles on a tank i usually make like 300 sometimes more on a tank.. I had changed the plugs like a year and half ago, do you guys think it might be just a bad tune up? oh and it has no codes Link to comment Share on other sites More sharing options...
flyfishing3 Posted December 9, 2007 Report Share Posted December 9, 2007 stage 0 time. Link to comment Share on other sites More sharing options...
Olive850 Posted December 9, 2007 Author Report Share Posted December 9, 2007 stage 0 time.where do i find instructions for stage0? Link to comment Share on other sites More sharing options...
855 Turbo Posted December 9, 2007 Report Share Posted December 9, 2007 change plugs, wires, rotor, distributor, air filter, fuel filter, oil change, and coolant change. if im missing anything, someone plz add it. you could check ur air mass meter too, mine was bad and i was getting about 11mpg.if you have any other questions, shoot a PM to me, ill be more than happy to help.good luck Link to comment Share on other sites More sharing options...
HPTDoh Posted December 9, 2007 Report Share Posted December 9, 2007 All the stage 0 stuff, plus SeafoamHere's the TB write-up I followed:http://forums.turbobricks.com/showthread.p...e+water+torture Link to comment Share on other sites More sharing options...
Dmsee Posted December 9, 2007 Report Share Posted December 9, 2007 Also dont forget new 02 sensors. That is probably your main problem. Link to comment Share on other sites More sharing options...
Black Betty Posted December 9, 2007 Report Share Posted December 9, 2007 just a question is there any way to truely diagnose a porr mpg symptom? i've read JBvolvo's threads and it seems like its pretty much replace various parts until the milage jumps back upsecond question he doesnt need to replace the rear o2 right? because it doesn't effect the Air fuel ratios does it? Link to comment Share on other sites More sharing options...
socal850tuner Posted December 9, 2007 Report Share Posted December 9, 2007 just a question is there any way to truely diagnose a porr mpg symptom? i've read JBvolvo's threads and it seems like its pretty much replace various parts until the milage jumps back upsecond question he doesnt need to replace the rear o2 right? because it doesn't effect the Air fuel ratios does it?um... no, the o2 sensors are a major factor in determining AFR's. The o2 sensor measures what if any air is left in the exhaust, this combined with the reading from the MAF determines the AFR. Also the since the fuel injection sequence is the variable that the ECU uses to keep the AFR's in check. In other words, if the o2 sensor is saying there is a lot of air, then the ECU sends more fuel. Link to comment Share on other sites More sharing options...
TBM Posted December 9, 2007 Report Share Posted December 9, 2007 Also dont forget new 02 sensors. That is probably your main problem.I think he would get a code if it was the O2 sensors. Another thing you might want to take a look at is that MAF sensor. Link to comment Share on other sites More sharing options...
Olive850 Posted December 9, 2007 Author Report Share Posted December 9, 2007 thanks for the replies, i will order a tune up tonight, but how do i check the maf and the air mass meter if its working properly or not, and if it isnt wouldnt it also send a code? Link to comment Share on other sites More sharing options...
7 VII 7 Posted December 9, 2007 Report Share Posted December 9, 2007 do a stage 0clean the MAFand replace the front O2 sensor.... done and done Link to comment Share on other sites More sharing options...
Olive850 Posted December 9, 2007 Author Report Share Posted December 9, 2007 i know this is a stupid question but how do i clean the maf without damaging it Link to comment Share on other sites More sharing options...
7 VII 7 Posted December 10, 2007 Report Share Posted December 10, 2007 i know this is a stupid question but how do i clean the maf without damaging itWrite Up! Link to comment Share on other sites More sharing options...
Black Betty Posted December 10, 2007 Report Share Posted December 10, 2007 um... no, the o2 sensors are a major factor in determining AFR's. The o2 sensor measures what if any air is left in the exhaust, this combined with the reading from the MAF determines the AFR. Also the since the fuel injection sequence is the variable that the ECU uses to keep the AFR's in check. In other words, if the o2 sensor is saying there is a lot of air, then the ECU sends more fuel.i know the o2 before the cat helps regulate the AFR but i thought the one after just told the ecu how effiecent the cat was working and didnt effect the AFR? am i completely wrong about that? Link to comment Share on other sites More sharing options...
