SWM Posted December 11, 2007 Report Share Posted December 11, 2007 On the dash info display where the outside temp and trip info displays, i have seen a "disc" readout flash off and on occasionally, sometimes staying on for a minute, othertimes only for seconds. cant tell when or why its on. searhced here and the manual to no avail. i have missed stuff in the manual before, so imight just be missing it. Can someone give me the lowdown? My initial thoughts were disc brakes or disconnect meaning it cant get the info for the display or something Link to comment Share on other sites More sharing options...
Zappo Posted December 11, 2007 Report Share Posted December 11, 2007 disconnected.It usually indicates a bad switch. You can try rotating through all positions a few times and see if it clears up. Link to comment Share on other sites More sharing options...
SWM Posted December 11, 2007 Author Report Share Posted December 11, 2007 ok, ill try that, and it reads fine 90% of the time, just occasionally popping in the disc error, which im sure will worsen if the switch is going south. Ballpark cost of the switch in case it ends up being in need of replacement? Link to comment Share on other sites More sharing options...
Zappo Posted December 11, 2007 Report Share Posted December 11, 2007 ok, ill try that, and it reads fine 90% of the time, just occasionally popping in the disc error, which im sure will worsen if the switch is going south. Ballpark cost of the switch in case it ends up being in need of replacement?You can find them used once in a while on here and eBay. Around $20 I think. Link to comment Share on other sites More sharing options...
1998C70T5 Posted December 11, 2007 Report Share Posted December 11, 2007 mine do that too but i just figure its thinking about what it wants to say. maybe its a faulty abs controller? a plugged up wheel sensor? Link to comment Share on other sites More sharing options...
Zappo Posted December 11, 2007 Report Share Posted December 11, 2007 mine do that too but i just figure its thinking about what it wants to say. maybe its a faulty abs controller? a plugged up wheel sensor?If it had anything to do with ABS, the tracs light would be on. DISC is solely the connection to the trip computer, nothing more. Link to comment Share on other sites More sharing options...
Serge Posted December 11, 2007 Report Share Posted December 11, 2007 INFO switch, re-plug it or replace it. Link to comment Share on other sites More sharing options...
850boston Posted December 13, 2007 Report Share Posted December 13, 2007 Definitely the switch itself, mine got so bad, that if I push up on it, the contact inside is made better and it works, if I push down on the switch, it save disc again. Nothing like a reproducible problem! Link to comment Share on other sites More sharing options...
