96PlatinumEdition850 Posted December 19, 2007 Report Share Posted December 19, 2007 Alright I changed my thermostat over the weekend with no problem and also changed the hose that goes from the resevoir to the thermostat with a silicone hose. I clamped and tighted all bolts but today when I walked out to my car the resevoir was empty and there was a noticable puddle on the ground of coolant. I think it's been leaking since the weekend but I wasn't parking in my driveway on monday or tuesday and couldn't tell. I think it's the silicone hose but I'd like any information as to why it's leaking. I don't think it's the radiator only because it was never learking until I did my thermostat. Anyways, anything to look for would be greatly appreciated.Also...is it true that when adding coolant the car should be on? Link to comment Share on other sites More sharing options...
Mike_P Posted December 19, 2007 Report Share Posted December 19, 2007 Alright I changed my thermostat over the weekend with no problem and also changed the hose that goes from the resevoir to the thermostat with a silicone hose. I clamped and tighted all bolts but today when I walked out to my car the resevoir was empty and there was a noticable puddle on the ground of coolant. I think it's been leaking since the weekend but I wasn't parking in my driveway on monday or tuesday and couldn't tell. I think it's the silicone hose but I'd like any information as to why it's leaking. I don't think it's the radiator only because it was never learking until I did my thermostat. Anyways, anything to look for would be greatly appreciated.Also...is it true that when adding coolant the car should be on?Hard to guess where it's coming from, where about is it dripping down from?. My bet is that it's leaking from the thermostat housing itself if you didn't get a good seal with the new oring/gasket.Did you remove the upper radiator hose from the thermostat housing when you did the job? The first time I did mine I disconnected this to make things a bit easier, and didn't get the hose back on quite the same as it was. I had a rather large leak once things heated up. Link to comment Share on other sites More sharing options...
7 VII 7 Posted December 19, 2007 Report Share Posted December 19, 2007 Alright I changed my thermostat over the weekend with no problem and also changed the hose that goes from the resevoir to the thermostat with a silicone hose. I clamped and tighted all bolts but today when I walked out to my car the resevoir was empty and there was a noticable puddle on the ground of coolant. I think it's been leaking since the weekend but I wasn't parking in my driveway on monday or tuesday and couldn't tell. I think it's the silicone hose but I'd like any information as to why it's leaking. I don't think it's the radiator only because it was never learking until I did my thermostat. Anyways, anything to look for would be greatly appreciated.Also...is it true that when adding coolant the car should be on?make sure when you put the gasket on the t-stat that you put it AROUND the t-stat and not under or on top of it... it has a grove in the middle of the gasket that covers the outer edge of the t-stat... Adam/OreO made that mistake. Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 19, 2007 Author Report Share Posted December 19, 2007 Definitely put the O ring UNDER the thermostat!Also the leak is around the passenger side front wheel. Link to comment Share on other sites More sharing options...
7 VII 7 Posted December 19, 2007 Report Share Posted December 19, 2007 Definitely put the O ring UNDER the thermostat!Also the leak is around the passenger side front wheel.FAIL no the t-stat gasket goes AROUND the t-stathaha Adam Jr. you are Link to comment Share on other sites More sharing options...
Oreo931 Posted December 19, 2007 Report Share Posted December 19, 2007 Definitely put the O ring UNDER the thermostat!Also the leak is around the passenger side front wheel.LOL Jeff did you really do this? I made the exact same mistake :lol: ... You probably shouldnt have posted this lololol. Go take off the gasket and put it AROUND the thermostat, there is a slit in it so it can fit around the thermostat.haha Adam Jr. you areWho are you, Yoda? Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 19, 2007 Author Report Share Posted December 19, 2007 Hahah, yea shouldn't have posted such a silly mistake but never would have realized it was such a silly mistake had I not posted. Thanks for the responses and I'm in the process of changing it right now. Thanks guys! For a minute there I thought I had a SERIOUS problem with the car not a SERIOUS problem with my head. -Stupid Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 20, 2007 Author Report Share Posted December 20, 2007 Problem fixed, now to install my new cap/rotor/plug wires. Link to comment Share on other sites More sharing options...
Chilled man Posted December 20, 2007 Report Share Posted December 20, 2007 Make sure you take a picture how they go back in other wise your car will run like crap. Figured I should say that after this moment of brillance :lol: Link to comment Share on other sites More sharing options...
'93 Dave Posted December 20, 2007 Report Share Posted December 20, 2007 Problem fixed, now to install my new cap/rotor/plug wires.is that is as easy as just marking the plugs then just unscrewing then screwing everything back on Link to comment Share on other sites More sharing options...
JBVolvo Posted December 20, 2007 Report Share Posted December 20, 2007 Problem fixed, now to install my new cap/rotor/plug wires.make sure you put the rotor UNDER the cap.....and the plugs, UNDER the wires. :D Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted December 20, 2007 Report Share Posted December 20, 2007 NICE JOB Don't tell me your as dumb as :) Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 20, 2007 Report Share Posted December 20, 2007 FAIL no the t-stat gasket goes AROUND the t-statThis post should have had a picture with it :D Link to comment Share on other sites More sharing options...
JBVolvo Posted December 20, 2007 Report Share Posted December 20, 2007 This post should have had a picture with it Link to comment Share on other sites More sharing options...
7 VII 7 Posted December 20, 2007 Report Share Posted December 20, 2007 3rd time in 2 days someone has called me Yoda Link to comment Share on other sites More sharing options...
